![]() | Home > General > Transmission Fault & HDC Unavailable |
| sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961
+1 sorry to hear. They might give you a new courtesy RRS when they are fixing yours. |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097
sad times |
| mlines Member Since: 10 Dec 2006 Location: UK Posts: 480
I had a similar problem on my 07 TDV6 HSE, rolled to a halt with Transmission and HDC errors, turned out to be the EGR valves on the engine! 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391
did you buy the car new? ============
a quick glance over, still can't find the answer. I found "Truck currently has 39k and is out of warranty" which doesn't help. If you bought it new from LR then you are in luck. ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
good luck ============
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
OUCH
Looking very briefly at the top WD policy http://www.warrantydirect.co.uk/pdfs/6727-...ryCare.pdf there's no reason this claim would not be met by it assuming you like a good fight. What is the difference between Luxury Care and Extra Care - which is the top WD one? ============ 2010 TDV8 HSE - ooo laa laaaaaaaaa 2007 TDV8 HSE - superb car and very reliable ============ 2012 - dearly departed, sadly missed.. to return in late 2013 with a new TDV8! |
Extra care has greater cover than Luxury Care
I don't know what the difference is but the following wording means you have a case
Very good point made there RRS gone
I just looked at the Extra care pdf, quite surprised the structure of it is so different to the other one (I assumed they'd all be the same layout, but different lists of included/excluded). Extra seems to be a specific list of what is covered, everything else excluded - unfortunately can't find wiring on the list of what's included or the term electrical connectors |
| Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497
I've learnt something then |
You must be well and truely p155ed off now |
| All times are GMT |
