![]() | Home > Technical > Height sensor gone rear n/s |
x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097 ![]() ![]() ![]() |
ideal not, if its sitting level you should be fine, its a relatively easy and cheap fix to replace the senor |
panda Member Since: 17 Jan 2010 Location: london Posts: 702 ![]() ![]() |
Thanks x5pea
they are tempramental mate , one of mine had an issue when i was down south, next morning problem was gone and it did another 20k with issue ![]() |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Pump car up to off road height and leave for a few hours. Any leaks will be more discernable from wheel to wheel. |
