Home > Maintenance & Modifications > Dead alternator
Dead alternator
Had the battery charging light come on on Tuesday morning as I drove to work. Checked the voltage across the battery and saw 12.4V with engine off, 13.5V with engine running. No change in voltage with lights and front heated seats on too. So battery charging still occuring.
Booked it in with LR at Oxford. Checked the voltage each time I used it. All as above.
Driving to LR garage this morning (Friday), the dashboard/centre console all went dark for a second before coming back to life. Error message on the suspension too now. Ah - that'll be the alternator finally giving up on life then says I. Turned off everything electrical (luckily it was just about light enough not to need headlights) and carried on to the garage.
Just had a call - after "a full diagnostic", the alternator has been declared dead. Replacement required and it's covered by the LR approved warranty. Phew! Unfortunately they don't have one in stock so the RRS will be spending the weekend at the garage. Hope to get it back on Monday.
Total use between first battery light and total apparent failure was about 5-7 hours of running.
Just thought I'd mention this in case anyone else has a similar failure and wonders about the possible outcome. If you have similar initial symptoms then don't try to do a long journey...you might not get there! 2012 SDV6 - it's missing a couple of cylinders
Post #327117 Fri Jan 06 2012 1:23pm
smurf
i am still licking my wounds after having the alternator replaced,not covered by waranty.
think it cost £340 fitted by my local garage
Post #327139 Fri Jan 06 2012 7:22pm
Bob.
Not much warning then, - good timing getting to the dealer. How many miles had the alternator done?
Bob
Post #327144 Fri Jan 06 2012 8:17pm
I bet rrsboy isn't commenting on this topic spouting how good the V8 is Laughing Another V8 alternator failure Whistle i bet you were glad it were covered under warranty Thumbs Up
Post #327152 Fri Jan 06 2012 8:44pm
simon1233
Ady, I have had to replace 2 alternators in 18 years of driving/ car ownership.n 1 was on my TDV6 RRS and 1 on the TDV8 FFRR, both within the last 12 months!
Speaks volumes about Landrover quality control but i still cannot think of another car I would rather own Thumbs Up
Post #327169 Sat Jan 07 2012 12:17am
Bob
Car has just hit 50k miles in 4 years. I assume the alternator is original. From initial failure to total fail was <200 miles 2012 SDV6 - it's missing a couple of cylinders
Post #327171 Sat Jan 07 2012 12:24am
Very glad! Thumbs Up
And it's not exclusively a TDV8 issue as indicated by simon1233's post.
The TDV8 does make up for it in other ways though Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #327172 Sat Jan 07 2012 12:26am
That's a lot less than I would have expected. Not a LR garage I assume? 2012 SDV6 - it's missing a couple of cylinders
Post #327173 Sat Jan 07 2012 12:27am
Bob.
Exchange alternator for a 07MY TdV8, £204 and LR time to change 2.2 hours. Made by Denso in Japan same as the starter and I'm on my third one of those in under 40k and no wading!
Post #327204 Sat Jan 07 2012 2:47pm
3 in 40k miles? Eeek!! 2012 SDV6 - it's missing a couple of cylinders
Post #327242 Sun Jan 08 2012 1:05am
