Home > My Range Rover Sport > Lamp Guards
Page 1 of 4 1234>
Lamp Guards
I have added a S/C Grill onto my TDV6 plus front and rear Lamp Guards. The most worrying bit is fixing the front guards - you have to make 4 holes in the grill! Shocked
 2005 Zambezi TDV6 - Gone but not forgotten
Post #32710 Tue May 16 2006 1:21pm
Very nice VA Thumbs Up RRS TDV6 Gone but still around
Post #32711 Tue May 16 2006 1:22pm
Andy
Looking good! Thumbs Up 2002 Discovery Adventurer LE
1998 Freelander xedi
Ertl limited edition RRS model number 817
Post #32713 Tue May 16 2006 1:33pm
Some pictures of the installation.
Front of RRS without Grill & headlight
Headlight area with 2 pluggs for the bracket attached
Bracket attached
Bracket with headlight attached
Rear light removed
Preparation for drilling
Holes drilled
Plugs inserted
Post #32714 Tue May 16 2006 1:52pm
RRUK
United Kingdom 2013 Range Rover Sport Supercharged Autobiography Stornoway Grey
I think they look very nice VA but ever since I had lamp guards on my first Range Rover I have gone off them because of practicality. Here's why:
1. They make cleaning the lamps harder as you get a build up underneather them, plus they catch the sponge/mitt, causing it to rip or tear. (a minor point I know)
2. You have to drill parts of your car to fix them on (I loathe doing that on a 60K car, the mudflaps was torture enough on the day I took delivery!)
3. If you bump into something (Or more likely, someone hits your car) and your lamp guards take the hit, chances are because they are fixed to the metal work, the stress of the impact will be transfered to the car body work rather than just allowing your cheaper and easier to replace plastic light unti from cracking or smashing. That may cause a much more expensive repair.
Has anyone else had this happen to them? L319 D4 HSE
1998 110 TUM HS FFR Hard Top XD WOLF
1982 Series 3 SWB
Post #32724 Tue May 16 2006 2:23pm
Thanks RRUK - and I was really Happy with them! Crying or Very sad Wink
Cleaning you have a point, but I'll get the local Albanians to do this. The rear guards needed 2 holes screwed in the bodywork behind the lamp cluster. The front guards needed holes drilled in the grill (the only worrying bit) Finally the guards are fairly light plastic and more likely to break than damage the car is any force is put on them. 2005 Zambezi TDV6 - Gone but not forgotten
Post #32726 Tue May 16 2006 2:27pm
Well you certainly get the " BLUE PETER " badge for effort. Bow down
Post #32727 Tue May 16 2006 2:27pm
IMHO, Lamp guards are very much a matter of taste.
Without wanting to offend anyone, I'm not a massive fan. They obviously serve a purpose but I'm not sure I like the look of them.
I suppose it's the same as running boards. I know there are people on here who love them, some who loathe them.
Misery fitted non-LR ones to his Chawton RRS because he thought that 'De-chromed' ones looked better with white. I much prefer the LR ones but that's probably because mine is Java. Runner up - 2009 Best Avatar Award Sad
Post #32728 Tue May 16 2006 2:30pm
Best thing is ................ it has kept VA busy - it's been so quiet on here Wink
Post #32730 Tue May 16 2006 2:33pm
Cliff H
I think it makes the front of the car look like it has Dierdre Barlows specs on.. Shocked
Sorry VA, good job !!!!
Post #32732 Tue May 16 2006 2:38pm
Misery
I was going to agree with you Supertrotter about the lamp gaurds. But after reading the rest of your entry you wont let these side steps go will you, Kam isn't on here as much as he used to be so he can't calm me down, you wait until after school Mad Mad Mad Mad
Post #32734 Tue May 16 2006 2:45pm
Misery
Post #32736 Tue May 16 2006 2:45pm
I'm with you "M" ...... I like the White ( a lot ) and IMHO your steps look good Thumbs Up
Post #32737 Tue May 16 2006 2:47pm
Alright Misery know your p***ed with SuperT about what he said about your side step's but you don't have to repeat yourself Laughing Wink RRS TDV6 Gone but still around
Post #32741 Tue May 16 2006 2:58pm
The reason I havn't posted much today is that my broadband is down - I'm having to use the northerners way of connecting - dial up! 2005 Zambezi TDV6 - Gone but not forgotten
Post #32742 Tue May 16 2006 3:00pm
Page 1 of 4 1234>
