![]() | Home > General > Why doe land rover not offer a 20" spare option? |
mlines Member Since: 10 Dec 2006 Location: UK Posts: 480 ![]() ![]() |
most likely its because there is not enough room for it. 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
20 inch wheel will fit under the car, both 19 & 20 have the same rolling diameter.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9128 ![]() ![]() ![]() |
Why would you want a 20inch spare? Unless you plan to rotate your spare out on to the car, it would be fairly pointless. The 19inch will suffice for the trip from puncture to tyre fitter for a repalcement main tyre. And for quite a large number of RRS on the road, the supplied wheels would have been 19inch all round. So LR would need to source a 20inch as well. Which would put the price up I guess. 2012 SDV6 - it's missing a couple of cylinders
swalker900 Member Since: 12 Sep 2010 Location: Bury Posts: 46 ![]() ![]() ![]() |
Just buys a bit more time to source a repair/new tyre if on hols in the alps etc. All new hse uk spec upwards RRS from my2010 come with 20" standard, so there are plenty of 20" wheeled cars out there. Just thought that land rover wouldn't have a problem offering a full sized spare as they do with new freelander 2 cars, as an option - unless there was size issue (tyre width etc)? New 20" single wheels are found in plentiful ly on fleabay, so thought I'd check before buying one ![]() |
Bob. Member Since: 03 Feb 2009 Location: SWest Posts: 275 ![]() ![]() |
Further discussion here:
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
and in summary for me a wider wheel/tyre combo will hang lower and potentially be prone to damage. |
I've had so many cars now with either 'space saver' or different spec spare wheels, I'd not even thought about upgrading to a 20" alloy to match the rest.
But not the same width (depth)? 2016 RRS 4.4 TDV8 Autobiography Dynamic in Montalcino Red and Stealth Kit |
lespes Member Since: 16 Jun 2008 Location: Channel Islands Posts: 1052 ![]() ![]() ![]() |
This must be one of those quirky Landrover things.
Cost, Space hanging below and im sure its an option Mike
Is it all to do with LR brochure quoted departure angle which is important for off roading?
