Home > Technical > Battery Earth Location
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
lo all,
Where is the earth connection located for the battery on the RRS?
Thanks
James
Post #325673 Mon Dec 19 2011 10:23pm
Bobby
Item 8 is the Battery Negative Cable.
 Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #325675 Mon Dec 19 2011 11:36pm
chapman_i.t
Thanks Bobby.
Post #325741 Tue Dec 20 2011 2:31pm
chapman_i.t
Does this cable hold the earth connection as well?
Post #326244 Mon Dec 26 2011 4:36pm
Bobby
HUH? You lost me there! Confused
What exactly do you want to know? Malaysia Boleh!
Post #326475 Fri Dec 30 2011 3:40am
Supacat
Bobby - I'm looking at a slightly different diagram published : Apr 30, 2004 that shows the opposite cable to be the -ve? I think the OP should check carefully before disconnecting.
The battery is located between the bulkhead and the secondary bulkhead, in a protective box, on the passenger side. It
sits in a tray and is secured with clamp plates and bolts.
The battery terminal posts allow for the battery cables to be connected with clamp type connections. The battery positive
terminal uses a pyrotechnic attachment, which detaches the battery cable in the event of a crash of a severity to trigger
the airbags. For additional information, refer to Air Bag and Safety Belt Pretensioner Supplemental Restraint System
(SRS) (501-20B Supplemental Restraint System)
All models are fitted with Delphi lead-calcium, maintenance free battery. Each battery is similar in construction with the
battery rating varying according to application. There are two different battery sizes:
�� H7 - All petrol variants H8 - TdV6
�� H8 - TdV6
The battery uses 'calcium expanded' technology, which has both positive and negative plates with grids expanded from a
strip lead-calcium alloy.
The battery is semi-sealed. Each casing has a vent to allow for thermal expansion and to vent oxygen and hydrogen
gases, which are produced under certain charging conditions.
Post #326482 Fri Dec 30 2011 8:12am
Bobby
This is a 2006 version...
 Malaysia Boleh!
Post #326485 Fri Dec 30 2011 8:27am
Supacat
Can't help thinking one of them is a typo - maybe the older one I'm referring to - as the cable looks near identical to that on the right of your picture but is labelled as a -ve!
Sun is shining so may go outside and check under the bonnet later
OP does not state what MY their car is?
Post #326493 Fri Dec 30 2011 10:23am
Bobby
Capital idea! Thumbs Up Malaysia Boleh!
Post #326496 Fri Dec 30 2011 11:16am
