![]() | Home > Technical > Engine Management Light on dash |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097
could be 101 things mate, unless its telling you the fault on start up suggest you get it into the dealer at your soonest |
| firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461
http://www.ebay.co.uk/itm/ELM-327-USB-1-4a...4154aec206
| ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298
Where does this plug in and apart from giving fault codes does it also say what the fault is |
not sure where your diag plug is mines under my right knee drivers side, it will give you a code and the software will explain what it is, and maybe able to clear it, if not the code is easy to find on t'internet. |
| Mike waldie Member Since: 09 Nov 2011 Location: Cronton Posts: 147
Happened to me today, any help I would be very grateful.... |
| NickM Member Since: 14 Feb 2008 Location: London Posts: 2995
Call breakdown if you're really concerned |
| mike21 Member Since: 07 Feb 2011 Location: Essex Posts: 297
Same happened to me a couple of weeks ago, was the EGR valve, replaced under warranty otherwise a £420 fix. The dealer did say the other one would probably go in a few weeks |
| mark hamster Member Since: 26 Nov 2011 Location: nottingham Posts: 116
when had mine replaced,other one went in less than a week |
| All times are GMT |
