Home > Technical > Wheels that will fit?
maddogsetc
Bought a set of 19" FFRR wheels for SWMBO's RRS but seems they won't fit over the calipers Big Cry . So now I need another set but don't want to make the same mistake again. Can anyone tell me for certain if these will fit?
http://www.disco3.co.uk/forum/post871940.html#871940
I know they are RRS wheels but not sure if there are different fitments - chap at the tyre depot suggested there was more than one type of caliper fitted Confused .
It's an 06 plate TDV6 HSE, currently on 20" wheels.
Post #325379 Fri Dec 16 2011 10:46pm
I have wheels that appear to be the same as those on my TDV8 so they should fit over the calipers on yours just fine. 2012 SDV6 - it's missing a couple of cylinders
Post #325384 Sat Dec 17 2011 1:02am
maddogsetc
Thanks RRSTDV8, that's good news. Presumably the V8 would have bigger calipers if anything Question
Post #325415 Sat Dec 17 2011 12:02pm
Mr H
England 2009 Range Rover Sport TDV8 HSE Santorini Black
+1
Just had the dealer stick mine over my brembos no problem, exactly same wheels Thumbs Up Have i got the busted controller?!?!!?
2009 RRS TDV8
Santorini Black
Ivory / Anigre
Privacy
DVD & TV
Side Steps
Post #325534 Sun Dec 18 2011 7:56pm
rr5port
2010 Range Rover Sport TDV8 HSE Santorini Black
19's or 20's, just make sure that they are 9.5J and they'll fit over Brembos no problem Thumbs Up 10 RRS HSE TDV8 --- No complaints so far
57 RRS HSE TDV8 --- Great Car. Heated Windscreen & Brake Module both replaced under warranty.
10 months great driving, before I couldn't do without the new interior
Post #325540 Sun Dec 18 2011 9:20pm
maddogsetc
Thanks folks, how do I tell if they are 9.5J? Is it cast onto the spokes?
Post #325545 Sun Dec 18 2011 10:07pm
muddywheels
Milk Float Man
Should be marked inside wheels Thumbs Up
I have 19's for winter - no problem Very Happy Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #325551 Sun Dec 18 2011 11:34pm
maddogsetc
Thanks Thumbs Up Thumbs Up
Post #325559 Sun Dec 18 2011 11:49pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
9.5j bit wont make any difference if the offset isnt correct ...... offset of ET as its stamped on the wheel should be on the back of the wheel. RRS and FFRR have different offsets if i remember correctly but i would have thought that the ET of the FFRR would be higher than that of the sport.
I assume its the inside spoke that fouling the caliper??? Make sure it is actually fouling as it does sit pretty close
Post #325582 Mon Dec 19 2011 10:42am
muddywheels
Milk Float Man
They look the same wheel I have fitted for winter - they are also 50 profile as required - discos usually have 55 Thumbs Up
RRS has 53mm offset - FFRR is 57mm but you can use spacers I believe but this may affect insurance as it is a modification Question Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #325589 Mon Dec 19 2011 11:51am
maddogsetc
Definitely foul, they showed me whilst it was on the ramp and it wasn't possible to push the wheel back into contact with the hub.
Sorry for being thick, what is ET? Mr. Green And how do you measure (or can you measure) the offset?
Post #325593 Mon Dec 19 2011 12:14pm
x5pea
ET is the distance in mm from the mounting face to the centre of the wheel
this picture will kinda help to explain
As suggested spacers will help resolve the issue , or just buy the right wheels.
Post #325594 Mon Dec 19 2011 12:23pm
maddogsetc
Thanks for the explanation Confused . So basically I'm looking for 53 stamped on the casting somewhere. I guess I can check the FFRR ones I already have to see if they have 57 stamped on them.
I'm pretty confident the ones I'm considering are original RRS wheels and at least 3 people seem to have them fitted okay, just a bit concerned by the suggestion there may be more than one type of caliper fitment and sod's law says I will have the 'wrong' one.
Am building quite a collection of wheels now Exclamation
Post #325599 Mon Dec 19 2011 12:41pm
x5pea
ON the founting face ull see ET listed
I think the only calipers are Brembos and non brembos as far as im aware.
If the FFRR is 57 then that a 4mm higher than the RRS ET so it doesnt make sense that they dont fit. U sure they are genuine wheels?
Post #325600 Mon Dec 19 2011 1:11pm
CeeJay4Fun
Sweden 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
IF the offset is 57mm for the FFRR then that would say that the center of the rim would go "in" 4mm more? In difference to RRS with 53mm not going "in" as much... and then if rim is curved then those 4mm could make calipers touch rim???
I have no clue... Just learning... and waiting on a message that some Scorpion tyres have M+S on them... Thumbs Up RRS 2010 TDV6 HSE Santorini Black
Volvo V60R D5 2011 Black
Jaguar XKR Cab 2002 Blue
Polaris Ranger 800HD Green
John Deere 6430 Premium 2009 IVT, GPS, Very green
Volvo L30B Pro 2012 Yellow
Post #325602 Mon Dec 19 2011 1:51pm
