Home > General > Ride height
panda
Ride height
Hi all.
Had car MOT'd obvoiusly they have to jack it up. The ride height seems to be higher than normal. The suspension goes to low, normal and high but it just looks higher. Could anything have happened when jacking up??
Thanks
Panda
Post #325348 Fri Dec 16 2011 3:53pm
shepp
Usually will ride high for a bit, BTW normal height isapprox 200mm from rim to arch with 20inch wheels.
Post #325355 Fri Dec 16 2011 5:18pm
panda
Thanks shepp
Just measured and it's 220mm but should settle down the 20 mm as I tried raising/lowering in my drive but havn't drove on road since.
Thanks
Panda Thumbs Up
Post #325358 Fri Dec 16 2011 5:29pm
It will not (cannot) lower 100% till it's been moved 10m or so after lowering... the wheel track width has to change slightly with ride adjustment... it's probably just under tension/compression RRS gone
Post #325359 Fri Dec 16 2011 5:33pm
