![]() | Home > Technical > Turning Right - Rubbing and becomes hard to steer |
| shepp Member Since: 15 Nov 2010 Location: Bingley Posts: 441
easy way to find out, take the wheel off and look for rub marks.
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
Obviously fouling something if you can hear rubbing
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097
Check drop links, wheel bearing and ARB mate |
| saferidges Member Since: 16 Aug 2011 Location: Basingstoke Posts: 14
The tyres are 285, 35r 22 106w's
do you know which wheel ist coming from ?
It 'feels' like its the driver side front wheel, though I cant be certain its not the passenger side wheel. I've checked the nuts and they seem to be on as tight as possible and the air is fine in both. Ill get it jacked up tonight at the local garage and see if there is anything untoward going on. Fingers crossed its nothing serious! |
I'd check the near side front 1st... if the noise is greater when on roundabouts.. greater loading on the front left, maybe bearing on the way out? RRS gone
| jrinns Member Since: 10 Dec 2010 Location: Midlands Posts: 88
I had something similar, sometimes steering would stiffen up to the right.
| All times are GMT |
