![]() | Home > Technical > oil top up 2011my |
Vadim Member Since: 20 Apr 2010 Location: London Posts: 855 ![]() ![]() ![]() |
I would wait till it says how much to fill in.
Thanks, your probably right as the quantity is difficult to gauge otherwise
SVR575 Member Since: 16 Apr 2008 Location: uk & Europe Posts: 1826 ![]() ![]() |
Mm i would still like a dip stick really. If you got the oil from LR main dealer should be the right oil, no. I know the castrol is a pain in the arse to find,but Shell also do the right one. |
Ive come to the same conclusion - the dip stick would be much easier overall...as much as i like the tech side - it means you dont check the oil as often and it isnt as accurate.
rr5port Member Since: 08 Jun 2011 Location: Northampton Posts: 43 ![]() ![]() |
Halfords Special
oldcro Member Since: 25 Aug 2010 Location: Shetland Posts: 359 ![]() ![]() |
http://www.opieoils.co.uk/c-1300-wss-m2c-934-b.aspx
I mentioned Opie oils - im aware they do 2 oils of the right spec (wrong manufacturer though) and as mentioned the Magnetec fully synthetic doesnt confirm to the current spec by JLR - you can buy it from a dealer...Jag dealers seem cheaper than LR dealers. My issue was more whether to fill it before it tells you...given the digital display ![]() 2014 Facelift Discovery |
Sorry, I must have missed your reference to Opie oils. As for dealers I was given the wrong oil by a Landrover garage and a Ford/Mazda dealer had never heard of such a spec of Ford oil, they did mention though that DPF's caused them a lot of problems. When topping up the oil level err on the low side rather than filling to the high level as synthetic oil expands quite a bit when hot. |
A dip stick would make life much easier |
