Home > Technical > Suspension air pump
SCdavies
England 2006 Range Rover Sport Supercharged Zambezi Silver
Suspension air pump
Hi people, just after a piece of mind please. My air pump is a little noisy when it firsts comes on and after 30 seconds its seems happy. There's no effort needed to ajust heights etc all works ok... is it on its way out Question Cheers.
Post #321395 Wed Nov 16 2011 11:01am
KR1005
Hong Kong 2006 Range Rover Sport 4.4 V8 HSE Zermatt Silver
i think is normal
Post #321410 Wed Nov 16 2011 1:12pm
x5pea
Scotland 2010 Range Rover Sport 3.0 TDV6 HSE Santorini Black
when you say noisy, can you hear it inside the car whilst driving?
The pump kicks in when the pressure in the system falls below 110PSI (if i remember correctly) will run filling the tank until its reaches 150 psi. You shouldn't be immediately aware of it running although on occasion you may notice its operation whist sitting in the car staionary in silence.
Its a consumable part but they should only become noisy if they are insecure, or if the pump workings themselves are breaking down. Usually they burn out and the first you will know is when its stops the suspension going up.
Post #321414 Wed Nov 16 2011 1:36pm
SCdavies
i hear it from inside and outside when i first start the car up as mentioned but afterwards it goes quiet and i dont hear it. It seems only on start up it makes the noise. Thanks.
Post #321417 Wed Nov 16 2011 1:56pm
x5pea
If its been sitting for a while then the pressure in the system will drop and when the car starts the pump will kick in immediately, on all my sports its not been overly noticeable, only time i recall hearing it in the background is when I was sitting in the car stationary with radio ect off. Similar level as the fan running on the cool box, its only noticeable if your listening for it.
Post #321421 Wed Nov 16 2011 3:25pm
