![]() | Home > General > Metal rim from side step came off? |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097
very common mate, usually the passenger side as its closest to the side of the road. From factory these are riveted on and over time the rivets break away from frame of the running board, most people replace them or refit them with a handful of self tappers.
| ajp166 Member Since: 10 Jul 2011 Location: london, UK Posts: 241
Thanks u so much..
na it will have fell off as a number of the rivets will have broken off, i susepct its getting a bit of purchase form one or more shalf of the rivets left on the metal trim. Id be more worried about it coming off at speed if its not secured properly, new set is 300 ish or get them refitted profesisonaly if your not handy enough to give it ago, its pretty straight forward happened to all of my previous sports. |
I will try this tomorrow... the metal strip is now off... its driver side... So I drill holes in the metal strip which has fallen off then drill holes in the side step so they match up and then screw together? maybe 4-5 small screws? |
Just drill the side step and put a few self tappers into the strip, u could do a small pilot hole if u wanted. Prob easier to drill bot atnthe same Time, ie on the car. |
Duh ofcourse you are right.... |
| Nik Member Since: 19 Nov 2010 Location: Up North Posts: 657
Out of curiosity at what age do they start wanting to drop off and are they covered under warranty?
| 0cj0 Member Since: 23 Sep 2010 Location: York Posts: 290
My ones fell off last year on an 08 ... and I had to fight to have them repaired under warranty :/ |
Mate what size drill bit did you use before? |
no idea, a small one that worked with the screws i had in the garage If your not technically minded just buy a new set mate, they are only 300 ish plus fitting for genuine ones. |
| Beancounter_74 Member Since: 11 Oct 2011 Location: Down here now... Posts: 5796
I'd say you only want something like a 1mm to drill a pilot hole. You just want something to guide the screw rather than have it shoot off at an angle. MERCEDES GL350 - Metallic Navy Blue w/Grey interior GOING: BMW F31 335D MSport+ xDrive Touring GONE: Land Rover Discovery 4 HSE - Stornaway Grey w/Black Interior (wish we'd kept it GONE: BMW F10 520D MSport - Carbon Black GONE:MY12 RRS SDV6 HSE Sumatra/Ivory/Grand Black Privacy glass |
The metal is quite thick so I glued and clamped it.... I will leave it an hour... a friend of mine is very good with things like this so if it doesnt glue he will drill on the weekend. |
I'd do both as unless your using tiger seal or a similar bonding product with a bit of substance so it I expect it won't last long. |
My mate has done an amazing job!
| All times are GMT |
