Home > Technical > Reversing Camera Guidelines - Do they bend?
As above. A friend has a Cayenne and when reversing and turning the steering wheel, the guideline tracks bend, showing the intended route of the car. On my RRS, they seem to be straight all the time.
Is that 'just the way it is', a fault, or is there an option that I should have enabled ? Handbook doesn't venture into too much detail Confused
TIA ON THE WAY: BMW F21 M140i
Post #321120 Mon Nov 14 2011 3:38pm
Jonny Fresh
Mine bend as you turn wheel
Post #321121 Mon Nov 14 2011 3:46pm
Hmmm, I thought that should be the case Big Cry
Will double check tonight, to make sure i've not knocked something on the screen. ON THE WAY: BMW F21 M140i
Post #321122 Mon Nov 14 2011 3:48pm
Lookers Park Royal
They only bend if you have the surround camera system (vision assist), if not then they are static....... strange but true.
James Thumbs Up
Post #321127 Mon Nov 14 2011 4:03pm
Just off the phone to LPR Service dept.
Turns out that unless you have the towing assist (which i assume means the surround camera's too), the lines are static, so its all ok Very Happy ON THE WAY: BMW F21 M140i
Post #321128 Mon Nov 14 2011 4:04pm
eddiek62
Scotland 2007 Range Rover Sport TDV8 HSE Buckingham Blue
Is it possible to get a reversing camera retrofitted by Land Rover onto a 2007 model?
Post #321129 Mon Nov 14 2011 4:04pm
James Thumbs Up
Thanks James, your very helpful service dept guy confirmed the same. Thumbs Up ON THE WAY: BMW F21 M140i
Post #321131 Mon Nov 14 2011 4:12pm
mrfixit
2011 Range Rover Sport 3.0 TDV6 HSE Stornoway Grey
You can via a GVIF unit. Thumbs Up
Post #321151 Mon Nov 14 2011 7:23pm
Or trailair system
Post #321152 Mon Nov 14 2011 7:31pm
mse
Whats odd with the bending lines is all the kit is in there without the camera's its just a software thing with the cameras it would seem! Mike
2014 Facelift Discovery
Post #321201 Tue Nov 15 2011 12:03am
Exactly, I wonder if it can be activated by changing the settings in the software somewhere? ON THE WAY: BMW F21 M140i
Post #321208 Tue Nov 15 2011 1:22am
Supacat
Send an email to BAS Autos - he's the software guru. I'd be interested in a "fix" to switch this functionality on as I already have the OEM reverse camera fitted but no trailer assist.
Post #321509 Thu Nov 17 2011 8:45am
