![]() | Home > Maintenance & Modifications > RSE AV1 to play on front screen in RRS with RSE - Help!? |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
I cant help on all the things but ill try to give you a few pointers.
| Netsters Member Since: 07 Nov 2011 Location: London Posts: 175
It's not so much the tv in motion that I am worried about, but the ability to have whatever is connected to the av ports displayed and sounded in the front of the car. What I need to find out is what connectors are on the back of the head unit, screen, and what connectors are on the back of the Rse module, and if it is a simple case of running a cable between the two, or are more electronics required? Range Rover Sport SVR - Santorini Black
Doing the research, found out the short answer is "no" RSE module only route AV1/AV2 inputs to the rear screens.
