Home > Maintenance & Modifications > RRS TDV8 57 plate Coolant level Require Top up Every 10 days
kennyt0804
United Kingdom 2008 Range Rover Sport TDV8 HSE Santorini Black
I am having to top up coolant level on RRS TDV8 every 10 days about 500ml each time. Any ideas??
Car runs like a dream
Post #320009 Thu Nov 03 2011 9:22pm
Egr cooler leaking Question
Post #320016 Thu Nov 03 2011 9:48pm
bootz
I started to get higher temps on my previous RRS TDV8 and on inspection the coolant level had dropped to just below minimum. The vehicle was carted off by LR recovery and the coolant system pressure checked but no leaks found. It happened just that one time - weird.
Having said that, it does sound like you may have a leak!
Post #320025 Thu Nov 03 2011 10:27pm
Alicatt
Belgium 2008 Range Rover Sport TDV8 HSE Buckingham Blue
There was a replacement expansion tank for '57' plate RRS as there was a fault with some. Mine was replaced a couple of years ago as mine kept doing that. Sons of dogs come hither and get flesh
Clan Cameron
Post #320194 Sat Nov 05 2011 2:31pm
Bearrubb1
England 2008 Range Rover Sport TDV8 HSE Java Black
Kenny any news on the leak?? My 08 tdv8 is doing the same??
Post #407855 Thu Jan 02 2014 6:46pm
Carlos3
England 2007 Range Rover Sport TDV8 HST Java Black
Had a similar problem with my TDV8 last year
After going into 2 different garages and them not able to find the leak . I borrowed a pressure tester and found the leak . it was right in middle of the engine down under all the electrical wiring where the 2 cylinder heads meet the block . A right pain to get to and five mins to fix a o ring on a pipe had failed.
Post #408262 Sun Jan 05 2014 10:27pm
Bearrubb1
Took mine in today Carlos hope they find it as pressurised mine twice and no leak told them to check where you said, fingers crossed Thumbs Up
Post #408345 Mon Jan 06 2014 3:53pm
Carlos3
Hope you get it sorted.
Post #408453 Tue Jan 07 2014 7:24am
I had a very slow loss of coolant on my 57 plate TDV8. Turned out to be a leak in the manifold that connects all of the coolant pipes in the V below the EGRs. 2012 SDV6 - it's missing a couple of cylinders
Post #408461 Tue Jan 07 2014 9:44am
Bearrubb1
Was it replacement manifold?? Where did you get it fixed
Post #408566 Tue Jan 07 2014 6:29pm
