![]() | Home > Technical > Whining/Wheel Vibration when lift off Accelerator Pedal |
yeah.. under load it's fine but when free-wheeling it's vibrating... I'd check the drive train joints RRS gone
B14RYW Member Since: 01 Nov 2011 Location: Edinburgh Posts: 58 ![]() ![]() ![]() |
thanks for this guys, really appreciate it
Guys thanks very much for the feedback it defo sounds like I need to get it checked out
actros Member Since: 26 May 2010 Location: cannock Posts: 2 ![]() ![]() |
had the same problem a couple of months ago ,it was the front diff pinion bearings, drain your diff oil if it is silver thats your problem,only did it on overrun fitting new diff cured it |
Thanks for the feedback. Turns out it is my diff that's knackered so a new one arrived today from CWS and it gets fitted on Friday |
