Home > General > Sun Roof or no Sun Roof that is the question
Richchad
I know it is a matter of personal choice but is a Sun Roof worth the extra £895 Shocked .....and is it too late to choose this option if the build date of my pre-ordered car is 22nd May for delivery in early June Sad
Maybe TB will know Question https://www.plus.net/refer.php?strReferral...d093cba6a7
Gone - RRSPORT TDV6 HSE
Buckingham Blue/Ivory, Privacy Glass, Tasmods Sills, Supercharged Black Badges all round, Grille & Vents, plus RRSport Sticker & Brolly of course.
Post #31880 Fri May 12 2006 1:05pm
Personal opinion, a thing off of the 80's before a/c became common fit.
Save your money, put air con on or open a window! Runner up - 2009 Best Avatar Award Sad
Post #31881 Fri May 12 2006 1:09pm
I like a sunroof myself and miss not having one.... you can change your order at this point. Depends if your salesman can be arsed to do the work Wink
Post #31882 Fri May 12 2006 1:10pm
I like the sunroof. Usually have it open a little for good air circulation. 2005 Zambezi TDV6 - Gone but not forgotten
Post #31888 Fri May 12 2006 1:17pm
Good point VA. Good for circulation however does it not rob you of headroom? Runner up - 2009 Best Avatar Award Sad
Post #31891 Fri May 12 2006 1:26pm
sportman
United Arab Emirates 2006 Range Rover Sport Supercharged Buckingham Blue
r u going off road this is the question? if yes it could be nice option specially if u like to keep ur all windows closed and get fresh air from top or u can take nice pictures if u will be driving in safari Laughing more safe to be away from lions..
Post #31898 Fri May 12 2006 1:37pm
No! it gives you 7,000,000,000,000 miles extra headroom! 2005 Zambezi TDV6 - Gone but not forgotten
Post #31904 Fri May 12 2006 1:43pm
Tim in Scotland
And if you forget to pull the blind over you sunburn the top of your head with it open! On the plus side, it you have parked the car in the full sun on a hot day opening a crack when the car is parked helps keep the inside a bit cooler - don't know if the alarm is affected by leaving it open though. I don't think it is worth the extra £895. Haven't had one on any car since 1998 and haven't missed it, as all my cars since then have had aircon or climate control.
Edit................ ooops just remembered my Defender which is dark metallic green, has no AC and gets like a furnace on a sunny day has a pop-up glass roof and fantastic under the screen louvre vents - you want colder, you have to drive faster or open the windows! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #31905 Fri May 12 2006 1:43pm
Richchad
I must admit I have have had a sun roof in both my previous Freelanders and have never opened them more than a few times, I was just thinking that the interior roof lining looked a bit plain after having a sun roof..... https://www.plus.net/refer.php?strReferral...d093cba6a7
Post #31921 Fri May 12 2006 1:54pm
Laughing Fine if you drive with your head out of the sunroof, but what about when it's closed!......... Rolling Eyes Runner up - 2009 Best Avatar Award Sad
Post #31928 Fri May 12 2006 2:01pm
KevinJM
Yugoslavia 2008 Range Rover Sport TDV8 HSE Java Black
Go for the sunroof. Apart from everything else, there's far more light in the car even with it closed and the blind open. I actually find the airco sometimes blows too cold, no matter how you set it, and anyway, long journeys with airco = blinding headaches at the end. nuff said! RRS TDV6 (gone)
RRS TDV8 HSE(gone, burned out)
ML 320 CDI Airmatic
Post #31936 Fri May 12 2006 2:12pm
Kevin - solution to your headache - leave the wife at home! Wink 2005 Zambezi TDV6 - Gone but not forgotten
Post #31938 Fri May 12 2006 2:13pm
Rolling with laughter Rolling with laughter Would they say the same about us? Runner up - 2009 Best Avatar Award Sad
Post #31939 Fri May 12 2006 2:14pm
Not if they know what's good for them (I checked and the wife is out of earshot) Wink
Post #32021 Fri May 12 2006 3:47pm
sportman wrote:
......get fresh air from top or u can take nice pictures ................. more safe to be away from lions..
Did,nt know you got LIONS roaming those big sand dunes over there Shocked
Post #32052 Fri May 12 2006 4:28pm
