| RRSPORT.CO.UK | ||
|  | Home > Technical > Realistic price for front ARB on TDV8 HST? |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097      | Nightmare job, chassis off in most cases LR authorise dealer somthing daft like 2 hrs to do the job where as in reality it's a day plus.
|  Fri Oct 21 2011 12:23pm |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097      | I just read that again it not the anti roll bar it's the bushes, my local guy charged me 200 inc parts lol | ||
|  Fri Oct 21 2011 12:32pm |
| TenBob Member Since: 01 Nov 2010 Location: North Posts: 138      |
 Not sure yet, hoping it's just the bushes. I have LR extended warranty but not sure if ARB (not the bushes) is covered, waiting for stealer to call back....   | ||
|  Fri Oct 21 2011 12:34pm |
 Wow that's loads cheaper than the indy near me! Thanks for the info   | ||
|  Fri Oct 21 2011 12:36pm |
| x5pea Member Since: 03 May 2007 Location: Lanarkshire Posts: 2097      | You would know if it was fuid mate as u would notice it on the drive way and eventually it will give you a suspension error. | ||
 Good point! I want my TDV6 back it was so much simpler!!! | ||
|  Fri Oct 21 2011 12:38pm |
| Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539      | A wee bit more work but local dealer is stating 5 hours and 3 for 4 wheel alignment on completion.
|  Fri Oct 21 2011 1:50pm |
| mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705    | Arb bushes £9,and it took me 10 mins to do 1 side and 50 to do the other,just because its harder to get the spanner in.And that was on axle stands not on a ramp at a comfy working height.Have you had the spacers put in before you change the Arb bushes? | ||
|  Fri Oct 21 2011 5:41pm |
 Are you talking about an ACE fitted car or standard suspension? | ||
|  Fri Oct 21 2011 6:36pm |
| mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705    | Standard,do you get a small consistant knocking(sounds as though its coming from the bulk head really)at low speed on small bumps/grids and the like,then it goes as you speed up. | ||
|  Fri Oct 21 2011 7:39pm |
 Yeah that sounds about right, big bumps don't seem to rattle it, nor does it rattle when travelling faster (above 50 ish) | ||
|  Sat Oct 22 2011 8:01am |
| mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705    | Ok sorry for late reply,we have a new puppy.Same thing on mine and they wanted £660 to replace the front wishbones,saying it was the bottom ball joints.I bought two ball joints and changed them and it didn't make the slightest bit of difference,they cost £36.I am prepared to bet anything that if you undid the arb bracket a bit and slip a 1 or 2mm washer up the back then tighten back up your knock will go.I used a C washer on each bolt cost under £1 and 10min job. | ||
|  Sat Oct 22 2011 11:43pm |
| Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497      |
 Why would it need the 4 wheel alignment doing after just changing the arb bushes? There is nothing they should be touching that would upset the suspension geo. | ||
|  Sun Oct 23 2011 11:55am |
| mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705    | I don't know why a dealer quotes 5-6 hours nor do I profess to know more about the car than them.What I do know is you get a compression of the rubber in the ARB bush over time(hence the market for poly bushes(a harder compound).The knock that is caused by this is the ARB Arm itself hitting the bulk head as it has raised collars to prevent sideways movement,it is this collar that gives you the knock,so if you increase the clearance it gets rid of it.The collar and bulkhead were polished due to contact on mine.
|  Sun Oct 23 2011 12:55pm |
| Posting Rules
