Home > Technical > Central Locking Receiver
chapman_i.t
2005 Range Rover Sport TDV6 HSE Java Black
lo all,
I believe I have a problem with my central locking receiver, both keys have been tested and work fine.
Is the receiver in the block in the middle of the roof? and also could it be a fuse that has blown?
Does anyone know which fuse it might be?
Any advice would be appreciated?
Thanks
James
Post #317487 Sat Oct 15 2011 12:54pm
firstinretail
United Kingdom 2005 Range Rover Sport 4.4 V8 Siberian Silver
whats the problem ?
could just need resyncing
Post #317506 Sat Oct 15 2011 6:42pm
chapman_i.t
The central locking works intermittently on both keys.
Sometimes you can go to the car and press the unlock button and it works but 95% of the time it doesnt work now.
Same with the lock button.
How do you re-sync?
Post #317528 Sat Oct 15 2011 9:56pm
muddywheels
Milk Float Man
Have you considered interference blocking your transmitter Confused
Does it happen in a certain location or everywhere Question Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Post #317530 Sat Oct 15 2011 10:19pm
chapman_i.t
I did think of that but the problem happens anywhere.
Post #317570 Sun Oct 16 2011 7:33pm
chapman_i.t
Nobody had any problems with remote central locking from the key fobs such as my problem?
James
Post #317964 Wed Oct 19 2011 8:22pm
DrLex
Iceland
Have a look on the D3 site - this thread has information regarding a wiring splice that has been known to cause issues.
Post #317998 Wed Oct 19 2011 10:06pm
chapman_i.t
How do you re-sync the keys?
Post #318212 Thu Oct 20 2011 10:41pm
Bobby
Re: Central Locking Receiver
chapman_i.t wrote:
Is the receiver in the block in the middle of the roof? James
chapman, I thought by now you should already know where/what the box is? I even showed you how the box
looks like.... http://www.rrsport.co.uk/forum/post316007.html#316007 Rolling Eyes Wink
You can restore the keys' synchronisation by starting the engine with the unsynchronized ignition key and
allowing the engine to run for a minimum of 6 minutes. Smile Malaysia Boleh!
4.2SC Chawton White, Stormers
Clear Side Repeaters, Towbar
Post #318234 Fri Oct 21 2011 12:31am
chapman_i.t
Yeh sorry I got that image.
What is the location of it though?
Post #318343 Fri Oct 21 2011 5:17pm
Bobby
The RF (radio frequency) receiver is ITEM #3...
Hope this is clear enough!! Wink Malaysia Boleh!
Post #318375 Fri Oct 21 2011 11:05pm
chapman_i.t
How do you access that without ripping all the roof lining out?
Post #318410 Sat Oct 22 2011 1:29pm
Bobby
Thanks for replying.
How indeed?
What do you actually want to do? Malaysia Boleh!
Post #318416 Sat Oct 22 2011 2:57pm
chapman_i.t
Well either A swap it or B check the connection to it.
Because I dont believe both keys have packed in at the same time?
I believe both keys are working fine and it is something internal thats the problem like the wiring or the receiver. But I dont see how anything could have changed with the wiring.
Regards,
James
Post #318436 Sat Oct 22 2011 7:59pm
Bobby
Have you tried to re-sync the keys?
Ripping the roof lining might be going too far.
Best would be to get a dealer to run a diagnostic and see if they can find the fault. Malaysia Boleh!
Post #318452 Sat Oct 22 2011 11:14pm
