![]() | Home > General > wanted, set of 19's / 20's |
caperbility Member Since: 14 Jan 2010 Location: landscaping the world Posts: 221 ![]() ![]() ![]() |
Ive got a set of 18s on fleabay at the moment if they are any good to you.
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9138 ![]() ![]() ![]() |
Just picked up a set of 4 19inch via ebay. Been quite a lot on there recently. 2012 SDV6 - it's missing a couple of cylinders
madkoka Member Since: 25 Aug 2010 Location: High Wycombe Posts: 39 ![]() ![]() |
Just had a look on flebay |
No problem thanks for the advice |
smoftah Member Since: 10 Jun 2011 Location: Kent Posts: 30 ![]() ![]() ![]() |
Hi I have a set of 19" wheels that came off my car sitting in the garage that are for sale. 1 Wheel needs a tyre as it is below the minimum 1.6mm on the edges, the other 3 tyres still have plenty of tread.
Depends on what you consider silly money I guess ![]() I might run these tyres next spring just to use them up rather than bin them. That means that I should be able to go for quite some time without buying new tyres - 1 set of 20s with decent life tyres, 1 set of 19 summer tyres of reasonable life and whatever set of winter/light mud tyre I get in the next week or two. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203 ![]() ![]() ![]() |
Pm sent. |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
I had 4 19" wheels with MTR rubber that was essentially brand new, for £875. I think I got them from this board actually in March 2010. ============
mrfixit Member Since: 23 Dec 2010 Location: Bolton Posts: 705 ![]() ![]() |
I've got these 19" spare 2 have tyres that have done 150miles.
maybe James LPR can clarify but there is a check you need to do for 19s on the RRS, something to do with brake caliper clearance? ============
I've emailed LPR just to make sure they will fit to MY2012 |
No need to contact James, there are stacks of posts here about it with regard to PRE 2010MY cars and some for post 2010MY:
Cheers |
there is something else.. which James knows because he was their when we blew up one of my 19's.. two 19" wheels might appear to be identical, but one design has a slightly different internal 'slant' that in turn fowls the brake calliper. James - where are you!!!?!!!?! |
