![]() | Home > Technical > Heated Rear Screen |
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 ![]() ![]() ![]() |
Fuse check? Now - MY11 RRS Autobiography TDV6, Orkney gray, tints, steps, daylight running lamps and allllll the toys!!!
Johnnyopolis Member Since: 12 Aug 2011 Location: Hampshire Posts: 137 ![]() ![]() ![]() |
I thought that but you can hear it clicking on... Will double check though! |
All fuses checked, its not that ![]() Are the rear side windows heated too? Johnny |
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
The side window elements are for radio and sat nav, so not heated. Some of my elements were damaged when I bought my car so only half the rear screen clears. Check all the elements they should be dark brown if they are light brown then the conducting material has been removed so they won't work! |
Are you pressing the correct button, not the front heated screen button by mistake? 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Mr H Member Since: 09 Sep 2011 Location: Lincs Posts: 427 ![]() ![]() ![]() |
I wouldn't admit that even if i was!! ![]() 2009 RRS TDV8 Santorini Black Ivory / Anigre Privacy DVD & TV Side Steps |
LOL thanks Tim, I was pressing the right button ![]() I should find out tomorrow as the car is going into RR to get it checked. John |
