![]() | Home > General > Help what have I done? |
Aitchy Member Since: 19 Nov 2009 Location: Peterborough Posts: 45 ![]() ![]() |
due to a puncture, (n/s rear) i have accidentally jacked the car up on a section of the car that is NOT the chasis rail. |
MikeS Member Since: 24 Dec 2009 Location: Parkdale, Melbourne Posts: 261 ![]() ![]() ![]() |
You've jacked it up on the air suspension pump and broken the bracket holding it on. The dreadful noise is the pump, if you're unlucky then that's knackered as well. Ex-G4 Challenge RRS HSE, BV55 YZE. Subtle shade of orange ! Now registered YZE481 G4RRS in Melbourne. |
rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391 ![]() ![]() |
yep, air suspension pump. This is a common mistake people make when changing the wheel |
barry15555 Member Since: 09 Oct 2010 Location: Essex Posts: 187 ![]() ![]() ![]() |
You need one of these, http://www.ebay.co.uk/itm/Range-Rover-Spor...2564f4b889 |
codfather Member Since: 13 Feb 2010 Location: ayr Posts: 1171 ![]() ![]() ![]() |
I have never got the AA, RAC etc out in the past to change a wheel, and always stop for a damsel in distress |
The Kergan Member Since: 14 May 2011 Location: Wiltshire Posts: 294 ![]() ![]() ![]() |
A tyre company done this to my D3 a while ago. I even showed the fitter where the compressor was and warned him to be careful where he put the trolly jack. Being a complete dick it went in one ear and out the other and he jacked up on it, this caused the D3 to suddenly drop when the compressor and bracket gave way. Damaged it to the tune of just over £1000,00. 2017 Range Rover Sport Autobiography |
deep joy! LR assist in place for an early morning review (prior to recovery as per the process) and then its over to the stealer for repair. Now I know its knackered I have remove the cover and can see the remains of the bracket. If its only that piece then not so bad, however, the ominous groaning noise suggests otherwise. |
Result! |
T8OOL Member Since: 16 Sep 2011 Location: Essex Posts: 242 ![]() ![]() ![]() |
sounds a like lucky escape there, thought you was in for a big bill...... RR Sport TDV8 09 Santorini Black with all the trimmings |
It would still be worth getting the car into a dealer for a check over. I would do it just for the peace of mind that something else like a pipe had not been damaged.
