![]() | Home > Technical > Creaking when Lowering/Raising |
| NickM Member Since: 15 Feb 2008 Location: London Posts: 2995
It's normal, most do it. Or when it lowers slightly when you lock it up..... |
| Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495
Is it? Mine doesnt do it. Could it be the bushers ? |
| sweetafton Member Since: 05 Dec 2009 Location: Weymouth Posts: 961
Yes mine does after I lock up. It's like it's farting, funny. |
Are you sure that isn't you |
Well now that you mention it I do like beans ady. Well that's sorted then. Perfect |
| KVT84 Member Since: 22 Sep 2011 Location: Calgary, Canada Posts: 2
The creaking was occurring while the RRS was in park/brakes applied...I've been reading some posts that seem to suggest it isn't wise to change to access mode when in park (instead it should be done when in motion)...is there any truth to this? Was the creaking a result of me changing to access mode when in park? |
| RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9155
I rarely use access mode and the only time I've heard a creaking noise is when I have used it (to help aged rellies getting /out of the back seats). Most likely it's because the geometery changes with suspension movement and you've effectively locked one end of the car with the park brake. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
