![]() | Home > Technical > Coolant Loss |
| RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176
Sorry to hear you're having problems.
| Southern Jock Member Since: 02 Nov 2010 Location: Newbury Posts: 69
Thanks Pat but there's no visible signs of a coolant leak which gets me thinking that it must be getting into some other part of the system or possibly the exhaust system?? It's got to be going somewhere right? |
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203
Just to clear an obvious one. When you say your topping it up, are you topping it up to the max fill mark or are you brimming the header tank?? Mine comes up with the low coolant message on a regular basis but it just the crappy level sensor gone wrong. |
I'm only filling to the middle of the cold fill range. Just had to buy another bottle of coolant from halfords at the weekend |
If its been pressure tested there's no guarantee that there isn't a leak within the engine somewhere. I had a supercharged BMW that threw a belt one day and didn't actually over heat but it was never right after that. You could do 300 to 3000 miles without a problem yet another day you went a mile up the road and it overheated. We tried everything!! Pressure tests included but never ever found the problem, but somehow from somewhere when it decided to lose water it did. Now dont panic because i'm sure there's nothing internal wrong with your engine, it may just be something silly. when the engines hot have you had a real good look under the bonnet and under the car?? There may be a tiny hole in one of the hoses or a tiny leek somewhere. You mentioned the egr system on your mates. Wonder if it makes a difference if you do the egr blank?? |
| All times are GMT |
