![]() | Home > Technical > Flat Battery |
| Boost Member Since: 18 Aug 2011 Location: North Lincolnshire Posts: 60
Went to get it out of the garage tonight, turned over a couple of times then died, Flat battery! Not been stood for long as I was out it it 3 days ago.
| chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950
As above, i would also check leads & earth.
| The Kergan Member Since: 14 May 2011 Location: Wiltshire Posts: 294
as above, all it can be really |
Just a thought, with you putting your car in your garage have you left your courtesy light on or have you left a door open or tailgate ajar |
Same again tonight |
| firstinretail Member Since: 30 Jul 2011 Location: bolton Posts: 461
based on that your battery would be flat in about 560 hrs (23 days) so my money is on the battery being |
Quite correct Right then so where is the best place to buy one, local motor factors or is there some good deals to be had on the WWW? Thanks for all your advice |
I can't help you on where to get one from but make sure you get the right one and not the cheapest off the shelf, i'm sure someone on here will know the right spec if you are unsure |
All sorted now |
