Home > Technical > Can you 'switch off' easy exit?
Mitch6176
Scotland 2009 Range Rover Sport TDV6 HSE Santorini Black
Does anyone know if you can 'turn off' the easy exit programme/process when getting out the car i.e. when you stop the engine and remove the key from the ignition and the drivers seat moves back and down a bit.
I'd prefer the driver seat just stayed where it is. Just personal preference so if anyone can help? If not, its not the end of the world.
Post #311211 Wed Aug 24 2011 9:22am
scrumps
According to the manual I've found it talks about switching the steering column position control away from "Auto":-
Automatic seat movement
If the control is set to the AUTO position, the
steering column and the driver’s seat will
automatically move when the ignition is
switched off. This allows greater clearance
when exiting and entering the vehicle.
The position of the steering column and seat
will be returned to their previous position next
time the ignition is switched on.
Note: To prevent automatic movement of the
driver’s seat, turn the control to its clockwise
position.
Smile
Hope this helps.
Scrumps Somerset - Where the apples do grow and the cider do flow!
2021 Defender 90 D250 HSE in Tasman with white roof.
24MY D300 AB - Verasine Blue - 😀
19MY SDV6 AB - Byron Blue - Gone
17MY D5 SDV6 HSE - Firenze Red - Gone
16MY SDV6 AB -Aruba Silver - Gone
13.5MY SDV6 "HSE Black" - Baltic Blue - Gone
10MY TDV8 HSE Galway Green - Gone
14MY D4 HSE in Scotia Grey - Gone
05 TD5 D90 CSW in Cairns Blue
Post #311213 Wed Aug 24 2011 9:34am
Jonny Fresh
Ah yes I remember this..............I liked it but my new one doesn't do it Confused
Post #311217 Wed Aug 24 2011 9:46am
Mitch6176
Thanks Scrumps, I'll try that. Thumbs Up
Post #311219 Wed Aug 24 2011 9:56am
andy r
2008 Range Rover Sport TDV6 S Zambezi Silver
I know the XF had this and it did my crunch...get in the poxy car, shut the door and all of a sudden the seat starts whirring and the wheel moves down and towards you, hated it 08 2.7 RRS "S"
Td5 110......very modified
RS 5
Kawasaki ZX12R Censored me, it's quick !
Post #311228 Wed Aug 24 2011 10:22am
Mitch6176
scrumps advice works a treat - thanks mate.
Post #311449 Thu Aug 25 2011 8:36am
