![]() | Home > Technical > Help Tow Bar Electrics |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
Confirmed - they are within the main fuse packs so integral to the cars fuse box. Mike
| leedsunited Member Since: 04 Aug 2008 Location: Selby Posts: 1368
Many thanks, does anybody know the fuse numbers or are they listed in the manual |
Hope you sort it, always annoying when the fuses are fine, especially when the fuses are split like the fault. Mike
Thanks, I will post back once I know, have a mate with a test unit for towing electrics and he is popping round to plug it in tommorow so I should have an independent view before I drop into the dealers. |
| airwolf222helicopters Member Since: 25 Apr 2010 Location: kent Posts: 248
just fitted a O.E.M KIT myself with new loom and fuse block in space in tool kit
Cant help you why you have the fuse block still...maybe old stock?
Ok update, the wiring kit does have a fuse block fitted, the dealer found mine behind the panel as I first suspected. Apparently it had been fitted as if it was a D4 install where it is installed behind the acces panel, now installed correctly in boot compartment and blown fuses now replaced. I will post tow electrics part numbers that have fuse loom later. |
| erfec10 Member Since: 20 Mar 2011 Location: Midlothian Posts: 47
just fitted a 13 pin system with the bus connectors from l/r and there is a in line fuse box which holds 5 fuses,i just placed it behind the near side pannel(hope i dont need to change a fuse)..........................
This is strange as there definitely isnt one for the 2011MY and it has the fuses in the fuse box - maybe disco and early range rover versions are different Mike
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163
I bet your problem is a poor earth, its up behind the rea n/s. Wheel remove and refit, 10mins. |
| All times are GMT |
