| RRSPORT.CO.UK | ||
|  | Home > General > rrs key/remote and cd |
| chrisonite_200 Member Since: 31 Jul 2011 Location: Essex Posts: 52      |
 I can only comment on the key...there is no battery its rechargeable !! Charges when key is in ignition !!   | ||
|  Wed Aug 10 2011 9:44pm |
| timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235      |
 Hi, I had a similar prob when i got mine, i think from the source button press that till you get the cd player showing, then press a disc number i.e. 1 as it has a six disc player when number 1 shows press eject or insert disc, then do the same select number 2 and insert disc and so on.
|  Wed Aug 10 2011 9:54pm |
| poolie Member Since: 29 Apr 2011 Location: teeside Posts: 138    | thanks for reply guys  | ||
|  Wed Aug 10 2011 10:13pm |
 Not 100% but if you remove the cover on the door handle you should be able to put the key in the door and lock it manually!!   | ||
|  Wed Aug 10 2011 10:16pm |
 Thanks  Itry that. Think the remote is fooked. Any idea how much anew one will be from dealers? Also can you get it in a day? | ||
|  Wed Aug 10 2011 10:30pm |
 My car went in 2 days a go and they didnt get a key in time as the spare one stopped working!! I think it all depends on the dealership!! They need to program it too!! You could just push the lock in when door is open from inside then close door...that should lock it...but remember if they key doesnt work you will have to remove the door handle cover to get back in!!   Good luck | ||
|  Wed Aug 10 2011 10:35pm |
| timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235      | Hi Chris, the other thing may be if car has been sat on the forecourt for a while to discharge key, then it may take a good while for key to recharge, so if you can leave it on the drive for a few hours with the key in ignition may restore charge?  | ||
|  Thu Aug 11 2011 5:14am |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | i think it throws a message on the dash if the key power is low? ============
|  Thu Aug 11 2011 9:28am |
| poolie Member Since: 29 Apr 2011 Location: teeside Posts: 138    | Had the car in dealers today (stratstone teeside) theyv'e checked key and said that its fine but still not working  the locks  | ||
|  Thu Aug 11 2011 4:36pm |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | my only comment would be that Stratstones do not have a very good reputation. ============
|  Thu Aug 11 2011 4:48pm |
| Very Annoyed Site Moderator Member Since: 23 Aug 2005 Location: bat-wielding monkey-spanking tough-love zero-tolerance Euro-sceptic moderator - So just watch it! Posts: 19459    | If you've just bought the car it's their problem and you shouldn't have to pay for the fix - saying that it is Stratstone's so nothing amazes me from that dealership. 2005 Zambezi TDV6 - Gone but not forgotten
|  Thu Aug 11 2011 5:56pm |
| poolie Member Since: 29 Apr 2011 Location: teeside Posts: 138    | Car was bought privately.
|  Thu Aug 11 2011 6:33pm |
| poolie Member Since: 29 Apr 2011 Location: teeside Posts: 138    | Can anyone tell me were reciever is in car for keyfob? | ||
|  Thu Aug 11 2011 6:47pm |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | give it a good charge. It's unlikely to be the receiver. ============
|  Thu Aug 11 2011 7:22pm |
| Posting Rules
 Been outside lock doors via dash switch but drivers is staying open.. Cant lock drivers door
