Home > General > How to remove.......
m22 gtr
Scotland
Just wondered how the side vents come of are they just held in with clips? Also I have a new auto gear knob to be fitted how does that come of and the strip at the bottom of the boot needs colour coding is it held in with clips? thanks
Post #308212 Tue Aug 02 2011 10:17am
Tug & Tug. 2005 Zambezi TDV6 - Gone but not forgotten
Post #308216 Tue Aug 02 2011 10:20am
Post #308217 Tue Aug 02 2011 10:21am
Tug and Tug and then throw away because the clips break.
Someone used a plastic knife iirc to release the lower clips without busting them. RRS gone
Post #308233 Tue Aug 02 2011 10:57am
JUCOTT01
Are you replacing with new ones ?? If so you should be able to see where the clips are located.
Open your bonnet and just by the hinge for the bonnet there is a small gap leading down the side of the inner wing,using a steel rule and maybe a torch you can release the first clip once you have it released you can use a bit of force to remove the others. I have removed mine a couple of times without problems,the drivers side is a bit more tricky as this one is you air inlet to the engine
This is how i removed mine on my MY11 sport hope this helps
Thumbs Up Thumbs Up RRS MY11 BALI BLUE OVERFINCH
Post #308593 Thu Aug 04 2011 12:39pm
jed.w
I removed my side vents with a credit card. Slip it under the bottom forward corner first, just gently push and the clip will pop. Didn't break any, took less than five miutes.
jed.w Thumbs Up SDV6 HSE Sport2 - Santorini Black, Ebony Interior, Pano Roof, Things I haven't found yet!
TDV6 HSE, Java Black, Black Premium Leather, Privacy, LR Side Steps, Smoked Side Repeaters, SC Vents and lots of toys!
Post #308652 Thu Aug 04 2011 7:52pm
