![]() | Home > Technical > DVD PLAYER WORKING! NOW A NEW PROBLEM WITH REAR SCREEN |
| Imo Member Since: 05 Aug 2007 Location: Shropshire Posts: 12
Sounds like the cable that runs up inside the back of the seat, it is poorly clipped to a horizontal cross beam and if it comes loose it chafes on the sharp steel of the cross beam and gets damaged. It is possible to remove the screen and lower the cable out of the back of the seat to see if a repair can be carried out. I did this ok and re-routed it to avoid the center of the cross beam. If not then a new headrest frame and wiring assembly is about £170 |
| All times are GMT |
