![]() | Home > Maintenance & Modifications > OBD II code P0172 |
| jhartz Member Since: 21 Jul 2011 Location: Virginia Beach Posts: 7
My SSC has 39,000 miles; over the last week I have been getting an amber engine light: code is P0172 (overly rich right bank). Problem is caused by computer enriching fuel due to perceived lean. Have been advised that there is a Technical Bulletin (PTB00231 for this issue); anybody have/seen? I have checked all vacuum lines, tightened the SC bolts; cleaned the the MAP sensor; used AMSOIL injector cleaner. After resetting the code; code is off for a day, then pops back on.
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
Have you changed the MAF? Mike
No, just cleaned it. If I need to, I will get the dealer to do it under warranty. I hate going there: they tend to sit on it. 08 RRSSC zematt Silver current
Did most of those fixes yu suggested. Still, P0172 keeps returning.
You cant clean the MAF (note NOT the MAP) the MAF is the mass air flow meeter on the clean air side of the air box. It really can be instrumental in how the car is fueled and usually prone to some form of error/issue Mike 2014 Facelift Discovery |
| andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370
MAF's are quite frequently messed up by the oil on certain types of performance air filters, the oil sticks to the wire element as it passes and effects the output signal. 08 2.7 RRS "S"
To quote my Brit friends: "Right!" Actually the Mass Air Flow Sensor can be cleaned rather readily on the both the 4.4 and 4.2 engines: it sits on the clean side of the air filter: you disconnect the the air tube from the air filter housing, unhitch (that is a techy term!) the connector; the mid tube is then removed; and the MAF sensor is a fine wire filament that can be cleaned with any variety of commercial MAF sensor cleaners; electronic cleaners work well, as well. I have always cleaned these about every four thousand miles on all three of the LR3 (Disco3) I have owned. In the LR3s, I was running KN air filters and they have a history (noted above) of gumming up (another techy term) the sensor. Usually use a injector cleaner (AMSOIL was my choice, but they have changed the blend and it is now much weaker) at the same time.
my experience says you cant clean the maf if its faulty - its faulty...them getting gunged up (as mentioned) is a more visible thing, but they break easily enough on their own!
I agree. Still, I would think you would get a 0101 if the filament breaks. 08 RRSSC zematt Silver current
As a final and followup: added Lucas Fuel treatment to 20 gal of gas; zeroed out the code; problem(knock wood) seems fixed. Ten drives, no engine warning light.
