![]() | Home > Maintenance & Modifications > Cleaning alloys |
npinks Site Moderator Member Since: 27 Nov 2007 Location: Watching Posts: 6716 ![]() ![]() |
Wolf chemicals deironizer (brake duster) then a sealant
RRS Craig Member Since: 14 Jun 2011 Location: Britain Posts: 139 ![]() ![]() ![]() |
As the wheels are brand new I'm
No the brand is wolf chemicals
Cheers pinks if I wanted to get the sealant you stated and a separate shampoo which would you suggest? Also do they do a cleaner for the dash, not dash board because it's leather. Cheers mate been really helpful looks good stuff! RRS |
I use the autoglym sealant and occasionally wheel cleaner - been on since new and takes 30seconds to clean.
Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515 ![]() ![]() |
+1 for the Autoglym aerosol spray. Cheap as chips and pretty good stuff. Doesn't last like the liquid sealants buts its a doddle to redo. FF 4.4 V8 Soooo looking forward to this bad boy
If you go for the nano sealent listed, I believe, (i'm sure Polished Bliss could offer advice) if you wanted a cleaner for the wheels then the other link to the cleaner/sealent would be your best option I used to rate Billberrys no acidic wheel cleaner, great for sealed wheels but not so good on burnt on dust ![]() For all my plastic dash (lots on the FL2 as you'll know) I use 303 Aerospace protectorant http://www.polishedbliss.co.uk/acatalog/30...ctant.html Great product as i can use on the dash, exterior plastic like mudflaps and engine bay plastic too, best thing is it doesn't leave it all shiny, its left clean and matt/satin finish. Says also can be used on leather too so it might protect the leather dash also (best check with PB on that) Every so often if I need to actually clean the dash, i will use a weak solution of APC (Meguiers All Purpose Cleaner) |
use detailing brushes to get in the gaps, like these, but cheaper http://www.polishedbliss.co.uk/acatalog/sw...-cat4.html |
THanks, Your right - been meaning to order one but always seem to remember when im cleaning it ![]() If i bothered i can get the brushes at trade if i place the order when i order other stuff. Mike 2014 Facelift Discovery |
i have used a paint brush in the past, just make sure you tape up any metal with some masking tape first of you'll accidental scratch the alloy if you hit it |
i wont ask how you know!! Mike 2014 Facelift Discovery |
gilford Member Since: 07 Jan 2010 Location: Anglesey Posts: 542 ![]() ![]() ![]() |
Bilberry, dilute to 50:50 and spray on, works a treat and doesn't have anything harmful in it! |
andy r Member Since: 04 Jul 2011 Location: Torbay Posts: 370 ![]() ![]() |
Best regular treatment I've found is that spray dodgy dealers use to make everything new & shiny, it stays soft & oily and normally comes of with a soapy brush, carefully spray it on, avoiding the discs and move around with a soft brush or cloth |
that will be acid then ![]() ![]() |
