![]() | Home > Technical > Flat battery |
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
Check the cables/connections and earth first mate. Common cause and often missed ending up costing people a fortune for no reason. |
Baron Member Since: 23 Jun 2005 Location: Southener Posts: 529 ![]() ![]() ![]() |
All the connections on the battery are in tip top nick ![]() Corris grey and ivory leather + most of the toys. Limited edition RRS model number 0001 ![]() Gone TDV8 RR Sport. Never to be forgotten. Wife has an i8 BMW |
baxc Member Since: 28 Dec 2008 Location: Lancashire Posts: 273 ![]() ![]() ![]() |
check your upper tailgate relies switch had the same on mine took me 3 weeks of testing to find the problem god knows how much it would have cost in the dealers to find the problem they tend to corrode inside take the outer rubber casing off if its corroded inside thats your problem m8 do a search on the forum battery drain and it will tell you everything you need to know about it |
Baxc ![]() ![]() Had trouble opening the upper part recently. Where abouts is it ![]() Corris grey and ivory leather + most of the toys. Limited edition RRS model number 0001 ![]() Gone TDV8 RR Sport. Never to be forgotten. Wife has an i8 BMW |
OK. Battery drain. I will go look |
Sure enough once the rubber cover was removed total corrosion evident. New unit fitted by dealer.
hope it cures your problem m8 let us know how you get on |
Car back from dealer. Bill £78. Part was cheaper than E bay item posted |
Got back from west country last night after a week away and car started this morning no problem.
no probs m8 |
no probs m8 |
