Home > Maintenance & Modifications > To Blank or Not To Blank, That is the question?
The Range Rover
United Kingdom 2012 Range Rover Sport 3.0 TDV6 HSE Lux Fuji White
Hi Guys
Let me pick your brains and ask your opinion.
I have a 2006 2.7 TDV6, is it worth blanking of the egr valves? i have read quite a few forums and there does not seem to be quite a differance of opinion.
Also is there a way of cleaning them out yourself, as I am quite a dab hand with a spanner and socket set.
There is nothing wrong with my beloved RRS , Iwas just wondering if it was worth doing?
Thanks
Colin
Post #273202 Fri Aug 06 2010 10:06am
Kerveunten
England 2006 Range Rover Sport TDV6 HSE Zermatt Silver
Actually i'd also be interested in whether this is worth doing. Any opinions folks? RRS 2.7TDV6 HSE, Zermatt Silver....no mods...yet!
Porsche Boxter 2.7, Lapis Blue (Gone & missed)
Alfa Romeo GTV 2.0, silver (gone and in a masochistic way, still missed...but i should know better)
Post #273263 Fri Aug 06 2010 6:14pm
Tim in Scotland
I have a Tdi300 TDi engined Defender that was delivered in 1996 with a cat when they were an optional extra. When the downpipe corroded and the cat was not working well the local non-franchised LR specialist I use advised non-replacement of the cat and removal and blanking of the EGR as leaving them in can cause problems with the ECU later down the line. So Cat was removed, EGR removed and blanked and the Lamba probe was removed result was a smoother running (does that matter in a Defender?) quieter engine and better mpg as the engine can breathe better, so if you have them removed take everything out and disconnect the electronics to save weird electrical problems with the ECU still thinking there is a a Cat and EGRs and it sails through the MOT with ease on the emissions front too 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Post #273269 Fri Aug 06 2010 6:33pm
lespes
Guernsey 2006 Range Rover Sport TDV6 HSE Buckingham Blue
Did mine couple of months ago. Now smoother 1-2 mpg more better pick up. Cost for kit from bells autos and fitting at garage just over a £100. One EGR valve replacement way more than that.
Viewed it as something that will fail sometime, so did it at my convienence.
Post #273292 Sat Aug 07 2010 1:06am
s1ras
Hi guys, my egr valves got clogged up on my RRS TDV6, i had the blanking kit fitted, it now drives so much better, and im getting better consumption! and at least theres 2 less things to go wrong now, i recommend it!
Post #278143 Mon Oct 18 2010 10:31am
iz6byo
replaced with BAS kit!!!!!!!!! Thumbs Up
Post #278176 Mon Oct 18 2010 9:19pm
The Range Rover
It Finally Happened!!!
Last night my Beloved RRS gave me the reduced power and dreaded black smoke!!!!
Took the plunge and blanked off my EGR Valves by making plates from stainless steel I had lying in my shed!
What a difference!!!! It was like driving a different car!
So in answer to my questio "to blank or not to blank"?
Is blank the Censored , don't hesitate just do it, you won't regret it
Post #305539 Fri Jul 08 2011 2:56pm
craneboy
Did mine just over a month ago and have to agree with the above.
Just do it, not even worth thinking about, took me just over an hour to do myself.
Cheers,
Andy
Post #305569 Fri Jul 08 2011 6:48pm
Martin
Site Administrator & Owner
Just a reminder for everyone reading, EGR blanking without error lights is only possible on 2006 model year and earlier TDV6s. 2007MY onwards are Euro 4 emissions standard which mandates the illumination of an error light when there's no EGR flow Sad Like this site? Buy some RRSPORT goodies to show your support!
Post #305570 Fri Jul 08 2011 6:51pm
iz6byo
1000000000000000000%.....
Bas kit and enjoy!!!!!!!!!!!!!!!!!!!!!!!!!!
Post #305574 Fri Jul 08 2011 7:41pm
I'm having a run up to bellauto's in the morning, i might just get the blanking kit while i'm there. Thumbs Up
Post #305582 Fri Jul 08 2011 8:22pm
iz6byo
Sure!!!! But he has a my06....
On my07 the dashboard shows some error....
Post #305632 Fri Jul 08 2011 11:02pm
garrycol
Australia
So what do you do to blank a post 07My and not get errors showing up???
Thanks
Garry 07MY RRS TDV6
Arctic Frost
Aspen Interior
Post #305635 Sat Jul 09 2011 2:36am
