| RRSPORT.CO.UK | ||
|  | Home > General > don't you love a good fault |
| panda Member Since: 17 Jan 2010 Location: london Posts: 702    | How much for a new sensor??  | ||
|  Mon Jul 04 2011 8:17pm |
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716    | If anything like my first FL2 With a similar issue about a fiver plus fitting for the water sensor | ||
|  Mon Jul 04 2011 8:21pm |
| panda Member Since: 17 Jan 2010 Location: london Posts: 702    | rrsboy If your off to the Alps why not just pay for the sensor. Job done. You then have 2 weeks to drive about to see if fault happens again.  | ||
|  Mon Jul 04 2011 8:29pm |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | principal plus at this rate I might just take their hire car.....   | ||
|  Mon Jul 04 2011 8:36pm |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916    | £13 but it looks an arse to do and probably would take about 5hrs to rebleed the system Mike
|  Mon Jul 04 2011 9:14pm |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | car is back with me now, sensor wasn't changed but I'm told a wire & connector were found disconnected. They control the fan speed and could have caused the car to overheat. Separately, the temperature sensor may be 'damped' like the fuel level sensor is, explaining why turning the car off and back on could appear to show temperature returning to normal (or something like that).
|  Tue Jul 05 2011 6:02pm |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | The temperature of the cooling system is monitored by the ECM via the Engine Coolant temperature (ECT) sensor located in the coolant housing. The ECM uses signals from this sensor to control the cooling fan operation. (The same sensor in the previous post).
|  Wed Jul 06 2011 1:03am |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | many thanks Bobby
|  Wed Jul 06 2011 10:48am |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | The Fuel Level Sensors [Magnetic Passive Position Sensor (MAPPS)] fitted to your vehicle are so advanced that it is practically impossible to be "damped".
|  Wed Jul 06 2011 12:38pm |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | thanks as always for the advice and info Bobby. To clarify when I say 'damped' I mean in the sense that as the fuel sloshes about the tank e.g. going up/down hill or around a corner at speed, the fuel guage doesn't move around wildly as you might expect (and as in car of 15 years ago). Somehow it filters out the big movements - this is what I term 'damping' but i'd love to hear how it actually manages it? ============
|  Wed Jul 06 2011 2:58pm |
|  Wed Jul 06 2011 8:59pm |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | superb - that is very interesting!
|  Thu Jul 07 2011 7:29am |
| Bobby Member Since: 07 Jun 2005 Location: Kuala Lumpur Posts: 3781      | No, it's different.
|  Thu Jul 07 2011 1:11pm |
| rrsboy Member Since: 06 Jan 2009 Location: UK Posts: 1391    | Bobby - does your 'bible' say anything about the fan continuing to run once the ignition is turned off? In cars of old this was a frequent occurrence, you'd park up and the fan would continue to run for a few minutes to keep cooling the hot engine. However I cannot get my fan to keep running no matter how arduous or long my journey has been? ============
|  Thu Jul 14 2011 6:28pm |
| Posting Rules
 . That was actually a fairly decent service (came out Sunday PM, brought replacement car this morning albeit with zero fuel and a 'service needed' message on the dash).
