![]() | Home > General > K&N Air Filter +MPG!! |
Are you sure it hasn't just leaned your fuel mixture out? If it has, over time it will just melt your pistons because the engine is running hotter. |
| kluklut Member Since: 23 Mar 2010 Location: Birmingham Posts: 45
errrmm... Ady!! Pls tell me you're just yanking his chain.... How does your filter lean your fuel mixture?!
| Streaky Member Since: 31 May 2010 Location: Dubai Posts: 259
Just do a search on any Land Rover forum for opinions on K&N filters |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
I've installed performance air filters on all my cars with superb results. (currently using a K & N like you)
Petrol and diesel engines perform a lot different to each other when putting add ons on such as air filters, Busters is petrol yours is diesel, the petrol engine burnes a lot hotter than diesel as you will already know this, its usually the maf sensor that gets contaminated and sends the wrong signal for the mixture hence it melts the pistons over time with no warning. Speaking from experience. |
| The Kergan Member Since: 14 May 2011 Location: Wiltshire Posts: 294
How would this work with your warranty, could LR refuse to pay out for an engine problem due to a performance filter like a K&N being used. 2017 Range Rover Sport Autobiography |
Yes, they will use any excuse to get out of a warranty claim, it all depends on how well you know you dealer, wink wink nudge nudge. |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
Take care
| avos Member Since: 26 Aug 2008 Location: Belgium Posts: 106 |
Lots of positive experiences with K&N filters on the 4.2 engines being it for RRS or Jaguar (as long as one speaks about the replacement panel filters). Over oiling could be an issue for the MAF, but so far I have not experienced this issue. You wouldn't get into a lean condition so fast, first of all the ECU monitors the mixture during gentle driving “closed loop”, and then adjust the fueling. In the meantime it will also set the long term adjustments for "open loop" driving, so when you floor it. These 4.2 engines are pretty rich already, so there the filter will not make a difference.
I would "normally" agree, however Buster007 is seeing a BIG change in MPG, so beg's the question, why? As I said earlier, check the colour of his plugs !!! In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
More info would be needed to understand what has happened there (Personally I only compare mpg with thousands of miles and 100 drive cycles at least, and even then it is only an indication…).
| npinks Site Moderator Member Since: 26 Nov 2007 Location: Watching Posts: 6716
Someone said to me the K&N filter was only good until it clogged up, even though they say 30,000 miles between cleaning and re-oiling, once they start clogging they clog quickly, then its another £10 on cleaning fluid and oil, which means whilst your doing this and waiting for it to dry from been run under the tap, before you can re-oil your without your car
| craneboy Member Since: 17 Feb 2011 Location: North Wales Posts: 111 |
There is so much scare mongering going on here.
| All times are GMT |
