![]() | Home > Technical > Coolant loss |
IGSYA Member Since: 20 Oct 2008 Location: Bristol Posts: 7 ![]() ![]() |
I have a bit of a problem with my Sport TDV6
RRSSTEVE Member Since: 17 Jan 2010 Location: POOLE DORSET Posts: 15 ![]() ![]() ![]() |
HI, IF YOU CAN SMELL ANTI FREEZE FROM THE EXHAUST THEN IT IS MOST LIKELY TO BE LEAKING EGR COOLERS ONE OR BOTH. |
MarkPowell Member Since: 16 Jun 2011 Location: Southampton Posts: 1 ![]() |
Just wondering if anyone can help/advise me. I have a sport 2.7 diesel. I had a coolant low message on my way back from holiday. i carried on with my journey as temp was fine. suddenly when i went to over take a car it lost power. straight away i looked at the temp and it had gone up to 3/4. i pulled over instantly. Long story short, a pipe had warn thorugh and leaked coolant out. They have fixed and refilled coolant and bleed system but its still pressurising. They are now saying it needs new a engine as the head gasket has gone but they couldn't be sure if anything inside the engine has cause it? any advise? surley they can tell if the engine is o.k apart from the head gasket. i dont want to replace the head gasket and then find something goes wrong and end up replacing the engine. |
P44RY C Member Since: 30 Jun 2008 Location: Cheshire Posts: 22 ![]() ![]() ![]() |
I have just had the same problem. Coolant loss etc.
Alicatt Member Since: 11 Jun 2007 Location: Eating in Eksel or Ice cold in Alex Posts: 1435 ![]() ![]() ![]() |
There was also a problem with the sensor and the header tank, there was a TSB about it and had mine replaced under warranty 2 years ago. Sons of dogs come hither and get flesh
Turned out I had a cracked Intercooler which was now replaced (£500)!
nosmokenopoke Member Since: 09 Jul 2016 Location: Gloucestershire South West Posts: 44 ![]() ![]() ![]() |
RRSSteve, I have just rebuilt the whole engine on my rrs and I have travelled only 100 miles and the water light come on and its smoking and using water. could the EGR coolers cause this and if so would it cause the truck to misfire. I rebuild engines all the time so nothing out the ordinary for me. I could of done something wrong as i am human but cant think of what it could be if i have. Is there anything to check before i take the body off and start all again Thanks Jon |
Hog Member Since: 03 Dec 2015 Location: Wassenaar Posts: 254 ![]() ![]() ![]() |
did you had the heads machined/ flattend? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5090 ![]() ![]() ![]() |
A complete guess, but there are 2 fuel/water heat exchangers on the car.
Andy, Yes there is one under the starter motor and one inside the middle of the two heads. To be honest i didnt even think of them. I wouldnt think it would be that as i am getting air/bubbles on a constant flow into the water tank. (pipe from radiator) also it smokes like a train. I is using the water fast. If you hold the trottle at 1500rpm it will clear but as soon as you idol it and touch the pedal it smokes bad. egr are not blanked. Andy if the egrs ever fail can they cause water to go into the cylinder as if not there no point me removing pipes ect. im sure its a head gasket now. I should have done the heads. Im going to do a compression test and see where it leads. Thanks jon |
From what you say it doesn't sound like the heat exchanger or EGR. |
cheers andy. Headgasket im sure
