| RRSPORT.CO.UK | ||
|  | Home > Technical > What's miles are the rrs engine gear box good for ?? |
| Imo Member Since: 05 Aug 2007 Location: Shropshire Posts: 12      | My 07 TDV6 has just passed 194K, the transfer box failed at 192K so I pulled the whole transmission and fitted a complete unit. Had the gerarbox checked and it was found to be absolutely fine, the transfer box needed a £15 bearing and is now also rebuilt and awaiting a new home with the gearbox. Had the unit double flushed at 150K and did notice an improvement so I'd say you've got plenty of life in it yet. | ||
|  Wed Jun 08 2011 4:12pm |
| erfec10 Member Since: 20 Mar 2011 Location: Midlothian Posts: 47      | does your rrs change gear slow or is it quite fast,
|  Wed Jun 08 2011 7:23pm |
| Jimmy07 Member Since: 01 Apr 2011 Location: Southyorkshire Posts: 62      | No really impressed with it out of junctions pulls right well and quick out of junctions | ||
|  Wed Jun 08 2011 10:35pm |
| drdelrrs Member Since: 02 Nov 2010 Location: UK Posts: 1163      | Unless you frequently use Low range and haul a maximum weight trailer you can forget about the life of the unit under normal road use. | ||
|  Thu Jun 09 2011 6:37pm |
| Jimmy07 Member Since: 01 Apr 2011 Location: Southyorkshire Posts: 62      | So what ur saying it ll go forever as long as it's serviced at right times
|  Thu Jun 09 2011 9:21pm |
| Posting Rules
