![]() | Home > Technical > How do you tell if lights are on in auto lights mode? |
| Vadim Member Since: 20 Apr 2010 Location: London Posts: 855
The standard green colour light (the same as when you put the lights on manually) lights up on the dashboard everytime lights are activated automatically. Vadim A. |
The RRS auto lights are one of the last ones on the road to light up, look for reflections on the car infront of you that usually lets you know if they are on or not |
| Bradders Member Since: 08 Oct 2009 Location: Leeds Posts: 2515
And in my case the last ones to turn off when exiting a tunnel into bright sunshine. FF 4.4 V8 Soooo looking forward to this bad boy
| Stephen Member Since: 15 Jun 2010 Location: West Sussex Posts: 30
I will have to check when i get home as I am sure that no green light comes on when the lights are actually on. In the right light I can see that the dials light up but mostly its quite difficult to tell if they have or not.
There is a little dial just below the light switch, have you tried adjusting that? It allows you to brighten or dim the instrument lights |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
You can also see where you are going, especially at night |
| mse Member Since: 08 Mar 2011 Location: Warwickshire Posts: 2916
thats overrated Mike 2014 Facelift Discovery |
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
The light indicator light didn't come in until MY09 / 58 ish IIRC - As your icon suggests you are in an '55 model i think the only way to know is a dimming of the cluster lights when auto on - flick between auto on and off to note difference (very slight). This is why the indicator light was intro'd |
| awd man Member Since: 30 Nov 2010 Location: Malmesbury Posts: 3355
green dash light appeared in 2007 |
Thank you for the replies. I am indeed in a 55 model but thought I was going mad as I could see no indication that lights were on ....because there was no indication. Agree though that is somewhat easier to tell in the dark! |
| All times are GMT |
