![]() | Home > Technical > 2008 to 2011 adaptive lights - WILL IT WORK? |
Is it really worth all the expense? Oh and don't forget the front wings |
| jundrill Member Since: 18 May 2011 Location: Epping Posts: 64
Someone must know? |
| kahndesign Member Since: 17 Mar 2011 Location: Bradford Posts: 484 |
you can change the car to 2011 spec and kee your adaptive headlights.
| Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495
Will this work affect the warranty?
not too sure foxy,
| RRS PIMP Member Since: 05 Nov 2008 Location: London Posts: 110
why does the wiring harness need to be changed? |
RRS PIMP did you just plug the new lights straight in (part numbers: LR023558/57) and they worked with no issue? No dashboard error lights etc and you didn't have to adjust the wiring looms or install resisters etc?
| ilard Member Since: 20 Aug 2010 Location: London Posts: 975
Just this one I just prefer the un-Gigged RRS's is all! Makes me a bit of an old crusty RRS TDV6 HSE Lux (MY2011)... Nara Bronze / Arabica - now gone! |
ilard so you've converted too using those part numbers and you had no issues at all? |
No, I'm factory standard. Most people I know prefer RRS's factory standard. L405 P400e Autobiography (MY2020)... Silicon Silver / Espresso
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
The only way I think an update like this should be considered is if you had a front end shunt, such as Geoff did on the Disco 3 forum http://www.disco3.co.uk/forum/topic65893.html?highlight=
SRE, that is my reason!! |
| 0cj0 Member Since: 23 Sep 2010 Location: York Posts: 290
Pm sent |
Get some photos posted, then we will be able to see the before and after. Syd In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures Gone - A couple of RRS, A couple of Disco's. However thinking of another Sport. |
