![]() | Home > General > Low MpG on RRsport 2006 tdv6 |
| SRE Member Since: 16 Jan 2010 Location: Alicante Prov Spain + Hampshire UK Posts: 2329
Check
| stormer2009 Member Since: 11 May 2011 Location: driffield Posts: 9
check egr valves i had to replace both |
| sjf1 Member Since: 23 Jul 2009 Location: London Posts: 37 |
Cheers for the tips, I do have my erg valves blanked, so can this still cause the mpg to drop if they fail? |
you should have egr valves they make a difference to mpg |
| dazzerboy Member Since: 18 Sep 2009 Location: staffordshire Posts: 212
hi ive got mine blanked and havent noticed a drop in mpg still get the same but i was told just the opposite that you should gain more mpg not lose |
| DSL Member Since: 17 May 2006 Location: Heelands/Cobham (delete as appropriate) Posts: 1045
Clean or change your MAP sensor. |
