| RRSPORT.CO.UK | ||
|  | Home > Technical > I pod I phone aux connection |
| ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298      | you just need a standard lead that plugs into the headphone socket..needs to be same at both ends...get one that is retractable ..easier to tuck it away than a standard size lead | ||
|  Mon May 23 2011 2:38pm |
| Jimmy07 Member Since: 01 Apr 2011 Location: Southyorkshire Posts: 62      | Oh right thanks what is the correct name for this lead so can search for one on eBay??
|  Mon May 23 2011 5:10pm |
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203      | I wouldn't bother. you can hardly hear it as the aux input doesn't go through the amp. | ||
|  Mon May 23 2011 5:19pm |
| ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298      | interesting mine seems to work and its plenty loud enough | ||
|  Mon May 23 2011 5:20pm |
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203      | When you say its plenty loud enough if the full volume on the stereo is 35, what would you say the volume is when plugged into aux?? Maybe there's something wrong with mine. I would say mine is half the normal volume. | ||
|  Mon May 23 2011 6:08pm |
| ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298      | just tried it and its about 5 units lower than the radio...you can adjust volume using the ipod/iphone volume setting and by using the amp in the car | ||
|  Mon May 23 2011 6:20pm |
| ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298      | dont know if it matters if your car has rear seat entertainment system or not...mine does and it uses the cars amplifier if it didnt when you turn volume control up you wouldnt hear anything | ||
|  Mon May 23 2011 6:22pm |
| simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421    |
 Aux input does go through the amp, but is controlled to be at a lower level. I would prefer that it was louder, but assume they have done this to allow for a wide variation in the volume of the input device. You'd be pretty mad if you managed to blow the amplifier by having an input that was too loud | ||
|  Mon May 23 2011 6:50pm |
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203      | well mine deff isn't worth plugging in. I have tried different leads with mine, messed around with the volume settings on my iphone and i've even tried the wifes iphone incase mine was on the blink but nothing makes it loud enough to listen to it above half volume. mind you!!! If i have the phone plugged into aux and it rings, thats loud! | ||
|  Mon May 23 2011 7:46pm |
| simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421    | felstmeister, have you tried a lead that goes from the dock connector to a 3.5 jack?  This is the loudest output you can get from an iPhone/iPod etc?
|  Mon May 23 2011 7:52pm |
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203      | yeah, another forum member sugested that when i first brought the subject up. I brought one but it didn't make any difference. Oh well!! Start burning some cd's   | ||
|  Mon May 23 2011 7:57pm |
| simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421    | Make sure that you only burn MP3's to the disk, car won't recognise anything that is AAC (tracks bought from iTunes), iTunes will convert any AAC tracks to MP3 for you though.
|  Mon May 23 2011 8:07pm |
| Jimmy07 Member Since: 01 Apr 2011 Location: Southyorkshire Posts: 62      | What's the name of the lead I need ??? | ||
|  Mon May 23 2011 8:33pm |
| felstmiester Member Since: 26 Apr 2011 Location: hertfordshire Posts: 203      | 3.5 to 3.5 Jack lead or iphone to 3.5 jack. | ||
|  Tue May 24 2011 7:05pm |
| Posting Rules
