![]() | Home > Technical > How do you remove the plastic cover under windscreen? |
RRS_PAT Member Since: 16 Dec 2010 Location: South Posts: 176 ![]() ![]() ![]() |
Hi Ronnie,
Is that the plenum chamber? Malaysia Boleh!
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 ![]() ![]() ![]() |
You could try this product: http://gtechniq.com/shop/3s-for-cars/exter...-restorer/
simon1233 Member Since: 06 Jan 2011 Location: Leyland mostly, sometimes Darmstadt Posts: 421 ![]() ![]() |
Autoglym bumper care - turned mine back to black |
Bobby -
Hope this is right. Malaysia Boleh!
iz6byo Member Since: 26 Dec 2008 Location: Italy Posts: 109 ![]() ![]() |
Just ordered....
mees Member Since: 17 Jul 2009 Location: bru Posts: 45 ![]() ![]() ![]() |
try some brake oil!
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 ![]() ![]() ![]() |
I think I would stick to son of a gun spray for it opposed to the brake oil me thinks ![]() |
Charlesrmh Member Since: 29 Aug 2010 Location: Middlesex Posts: 5 ![]() ![]() |
Be careful when removing the panel, as it has a tendency to deform and when reinstalled can then leave a gap between the screen and the softer edge of the plastic. Mine was damaged by the windscreen installer and had to be replaced due to the way the trim tool was used to detach the clips. Charlesrmh |
Bobby,
1JBS Member Since: 30 Oct 2010 Location: Henley on Thames Posts: 530 ![]() ![]() ![]() |
I have just improved the look of mine with Autoglym Bodyshop Plastic and Rubber Cleaner 07 B it now looks much better, this also works well on the black trim either side of the windscreen and the mirror covers. |
