![]() | Home > Technical > Brake Pad Warning Light |
| ELD70 Member Since: 19 Jan 2009 Location: UK Posts: 163
Sounds like a wiring fault, maybe check all the connections under the wheel arches for damaged/rubbing or corroded wires? |
| ashleyandash Member Since: 18 Oct 2010 Location: Leek, Staffordshire Posts: 11
Thanks for the reply, do I need to do anything other than raise the suspension and inspect?
| MAW Member Since: 06 May 2006 Location: Lincs Posts: 3104
The connectors can be a struggle to undo - check that the upstream connector is still sound and the wires have not been disturbed in the swap over - sensor is rear right from memory (& front left) but you can see it anyway. The sensor closes a circuit until worn 'open' IIRC.... |
| All times are GMT |
