![]() | Home > Maintenance & Modifications > Brake disc/ rotor replacement with pads |
JimboTD5 Member Since: 29 Jan 2010 Location: Hertfordshire Posts: 113 ![]() ![]() ![]() |
Take a look at this detailed brake bible produced by Bodsey of the D3 site, its brilliant |
ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298 ![]() ![]() ![]() |
If the discs need to be changed you should change the pads as well as the original pads have effectively worn with the old disc. If you look at them really clost you will see that they are not perfectly flat or smooth. You will get uneven wear in any brake system that uses sliding calipers ie the rear brakes. It isnt a difficult job so for me if u change the disc change the pads as well |
Supacat Member Since: 21 Feb 2009 Location: West Yorks Posts: 497 ![]() ![]() ![]() |
Sounds a really great price - where was that from? |
