Home > Technical > Brake Pads..is this normal???
ChrisP
If in doubt I would take it down to LPR I'm absolutely sure they will give you an honest appraisal as it does seem as someone is legging you up Shocked MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Audi A5 Sportback Black Edition 3.0 tdi quattro S Line
Post #298800 Mon May 09 2011 7:12pm
timcom0
lauretta29 wrote:
ok....update on my car. Apparently, the car has now had a full inspection and there is "nothing wrong with it". However, just spoke to another Land Rover dealer who said he and his workshop foreman had never heard anything like it. The garage that it's at wants to charge me £295 for changing the rear pads-think they are taking me for a ride. What do i do? Is there a motor association I can call to help me????? Need some top advice!!!
take the car straight out and to another garage for a second opinion then if they state different get on to LR Customer service, take it to the garage you spoke to then claim for wasted time etc i did great outcome
Post #298802 Mon May 09 2011 7:14pm
SVR575
Hadley green ??? Near you? SVR 2018 in Santorini Black.
Post #298804 Mon May 09 2011 7:16pm
lauretta29
2009 Range Rover Sport TDV6 S Alaska White
The car is at Hadley Green at the moment. The guy from Head Office that we've been speaking to has basically agreed with the inspection done at the garage and said there was nothing more he could do. I just have to pay for the rear pads to be done!!
Post #298808 Mon May 09 2011 7:23pm
SVR575
wasnt sure if they where any good, now we know! SVR 2018 in Santorini Black.
Post #298811 Mon May 09 2011 7:29pm
leedsunited
United Kingdom 2008 Range Rover Sport TDV6 HSE Java Black
Re: Brake Pads..is this normal???
lauretta29 wrote:
Hi, my Range Rover Sport 2009 has been picked up by Land Rover Assistance and is currently at the Land Rover Garage. My brake pad warning light has come on again. The garage have said that I need another set of rear pads. This will be my 3rd set of rears in 2 years and my fronts are already on their 3rd set. I have only done 19000 miles and use the car for local journeys only. I have also had two full sets of tyres in the same time. Do you think this is normal???
Shocked Shocked Shocked Shocked Not at all, 2.7 HSE 47K miles and one set of fronts and one set of rears, somebody is having your eyes out.
Post #298891 Tue May 10 2011 1:41pm
SRE
Spain
Rear pads, circa £50
http://tinyurl.com/6bxgq6p
You need to find a better dealer. In Spain - 2018 F Pace - Frightened away from the Sports due to crank failures
Post #298903 Tue May 10 2011 4:54pm
is the nature of your driving tough on pads?
Do you do lots of short journeys, maybe involving wet roads? Whistle
Have to ask... my Porsche went through a set at 21k and when I complained they said it was corrosion on the disks causing excessive wear.. reason for corrosion, cool wet disks due to short journeys resulting in surface rust. RRS gone
Post #298906 Tue May 10 2011 5:16pm
lauretta29
ok, now for the best bit. After taking advice, we decided to have the car looked at by another dealer. My husband instructed that all work was to be stopped on the car and that the old pads should be put back on, so we can take it out to another dealer. This morning, we got a call from Hadley Green to say that all the work had been completed and my car had a lovely new set of rear pads on it!!!! Now been advised by 2 other dealerships that any other inspections now wouldn't show up any problems because the new set of pads had been fitted. They have proper screwed us!!!
Post #298955 Tue May 10 2011 10:16pm
leedsunited
Not if you hav'nt paid Thumbs Up
Post #299009 Wed May 11 2011 10:18am
ChrisP
Did you authorise them to fit the rear pads Question MY2011 HSE Santorini/Ivory/Piano Black/Privacy Glass/TV .Sadly gone.
Post #299091 Wed May 11 2011 5:21pm
drdelrrs
May be completely unrelated but I had a Jaguar XF which neede rear pads at 12,000 miles. This is the first car I've had in years that required rear pads. Only ones that have have done over 50,000 between sets (BMW).
JLR's response was that the stability control system (DSC) automatically applies the rear brakes as it feels necessary for optimum car stability and if you are in the habit of entering corners/roundabouts relatively quickly the DSC will be activated and the rear pads will suffer.
In my case I didn't agree because the rear tyre wear was less than the fronts and had the stealers do a warranty claim.
The RRS is a heavy vehicle which would make the situation worse and I'm not sure if the RRS is using a similar approach but you might want to ask relevant questions and check out the rear tyre wear compared to the fronts.
Post #299099 Wed May 11 2011 5:46pm
