![]() | Home > Technical > Strange noise, could it be gearbox? |
| will_wonka Member Since: 03 Mar 2007 Location: Tminus 12 months for the RS Sport Supercharged!! Posts: 3377
I know you mention "only in gear" but could be something stuck in the hub? I had a stone wedged somewhere on my RRS and it sounded like grinding metal........just a guess. |
| Siberianfox Member Since: 12 Mar 2011 Location: West Yorkshire Posts: 1495
thats exactly what mine did when i cam out of the water see the burghley water pictures... I took it to the jet wash and powered washed the wheels it resolved the issue.
| Vadim Member Since: 20 Apr 2010 Location: London Posts: 855
SiberianFox,
Just got the car in to Lookers, went for the test drive with an engineer. He says it could be the drive shaft, after the test drive he looks at te tires (I have snow tires installed) and says the tires could be the cause for the drive shaft get like that "noisy". They'll put on summer tires and see if it still has the problem.
| Portman Len Member Since: 09 May 2011 Location: Suffolk Posts: 57
Hi all. First post about my shiny new RRS 2011 HSE - only had her 6 weeks. Tonight I had EXACTLY the same problem as Vadim which was a really loud metal-on-metal sound from the front right wheel when moving really slowly - especially in reverse. The car has just been collected and sent up to my dealer Hammonds for investigation, but as the car is only 6 weeks old, and is factory spec, I know it can't be the tyres.
| ronniet101 Member Since: 10 Mar 2007 Location: West Country Posts: 298
I had this mettalic sound apparently coming from the front ..turned out to be the bearings on the rear diff on their way out..diff eventually changed by dealer
Thanks for that. The car has been delievered to the dealer so I should have some feedback hopefully tomorrow as to what they think the problem is.
I got my car back from Lookers. They said they took apart the drive shaft apart and found some dirt on it?... so they cleaned and lubricated it nicely and put back together which hopefully should cure the problem. On the way home, again when reversing, I heard the noise again...Also, I noticed that it can be heard when moving forward (from stationary), however it is more common to hear it in reverse. Also, I heard I think the same noise when lowering to access model. I can actually see how Lookers thought they'd fixed it because it can only be heard every 5th time when reverse is used.
Phone call back from my dealer at 5.30 to advise me that they can't find anything wrong with the car. It was making the metal on metal sound first thing this morning but after having the car up on the ramp, the noise stopped. Anyway, Hammonds will take another look at the car first thing in the morning and if it still is not making a noise, it will be returned.
| Frosty_Power Member Since: 02 Oct 2008 Location: Calgary Posts: 93
I'm getting mine looked at tomorrow for the exact same thing except mine has gotten to the point where the noise is really bad. I believe it is a front passenger wheel bearing that is loose but I will find out tomorrow and do a follow up. The front wheel assembly was loose when I pulled the tire off and I noticed the rubbing noise was the rotor metal grinding to my brake guard metal and did it mostly in reverse too at first but now is really loud, especially over small bump. It looks like I will need new rotors too since they are caved in a bit where it was grinding with the guard. Mine is 5 years old though, not 6 weeks like Portman. I'll post back in a couple days. |
Mine certainly appeared to be coming from the driver's side front wheel, but since having the car back all is fine. I do know that my dealer changedall of the brake pads on all four wheels so not sure if that has anything to do with it or not.
Hey Portman, yup it was my wheel bearing, had to get rotors replaced too as well as a bunch of other stuff with the RRS. Lots of grinding but now all gone.
