Home > Maintenance & Modifications > Which brake pads
smurf
Which brake pads
i am due to have my brake pads replaced in about another 3k miles.i have seen the red green and yellow ones and wandering which ones will i need.i have a 2007 hse with brembo's on the front,any advice please
Post #298759 Mon May 09 2011 2:53pm
Siberianfox
England 2011 Range Rover Sport 3.0 TDV6 HSE Siberian Silver
What the colour of your calipers? Smile
Post #298763 Mon May 09 2011 3:05pm
JimboTD5
England 2008 Range Rover Sport TDV6 S Buckingham Blue
if you have a LR warranty you may want to consider using genuine LR parts, not sure if it would be a issue if they found non genuine parts were being used.
Jim
Post #298766 Mon May 09 2011 3:13pm
shepp
I would replace with another set of brembo's. They are dear but prob better than most others. No point in having fancy brembo calipers then rubbish pads and discs
Post #298789 Mon May 09 2011 6:20pm
smurf
cheers guys.
the calipers are black and i have seen the red green and yellow pads at the land rover dealers so surely they should at least be approved?
thanks shepp i will look at the brembo pads
Post #298805 Mon May 09 2011 7:17pm
