![]() | Home > General > What would you think? |
(Not my car, a friends)
chris mc Member Since: 03 Sep 2010 Location: Dundee Posts: 950 ![]() ![]() ![]() |
This could be a tricky one.
Not that I am aware of Chris
Steuart64 Member Since: 24 Dec 2009 Location: Aberdeen Posts: 539 ![]() ![]() ![]() |
If the pulley was expected to fail at the same mileage then it should be part of the replacement work. As it wasnt part of the work we can assume it is meant to last longer and maybe LR may make a contribution?
I think thats what failed on tims car and destroyed his engine, LR replaced the complete engine at their cost. His mileage was in the 90's though. |
As an ex-dealer principal (not JLR) I'd be highly suspicious that they may have damaged it in the process of changing the belt. A pulley housing is nota "wear and tear" item, it requires not maintenance and should last the ,fe of the car unless damaged in the process of dismantlng and re-assemble !!
timcom0 Member Since: 11 Jul 2009 Location: Sheffield Posts: 235 ![]() ![]() ![]() |
Not quite the part Ady, but first question is what is the service detail on the pulley or when is it programmed to be changed in the service schedule or has it got a part number, I ask due to the fact the chain that links the cam shafts went on mine and has no part number therefore programmed to last the life of the engine. Also when it had no part number or service indicator classed as premature failure. |
I'd definately be suspicious, when i took mine to the dealers they actually billed me for checking cam shaft and timing although the chain had gone and wasn't turning between the pulleys therefore how can you check it. He needs to stand his ground and if necessary take it to a separate dealer for second opinion worked for me |
I doubt it OM, yours is petroleum ![]() 5 series for the miles ![]() RRS S/C factory built HST - Gone 45 others have been and gone! |
cheers everyone I'll pass on the advice |
